torsion capacity
Dear sir,
Kindly confirm staad is calculated the Tortion capacity or not. If it calculates how we can check coming Tortion in the beam is less than the Tortion capacity of beams.Staad file is attached kindly advise the stringers are safe on applied tortion and how we can check it is safe.Attached picture is not giving tortion capacity of stringer.
Thank you in advance.
STEEL STAIRCASE.std
Parents Reply Children
