thanks for your time and support that it is always great.
current license is STAAD.PRO (normal)
The company where I am working is thinking about RCDC (Advanced Concrete Design workflow) design scopes because we need to performance RC design under Eurocode standard.I checked in the website
docs.bentley.com/.../GUID-3DE53107-9A2F-473A-88B8-7DD893843885.html
Using RCDC license, we can make RC design using Eurocode standard, I understand, but I am worried for the output that we can receive from that. Is it possible to obtain the output considering all the following list please?:
①The demand capacity ratio under Bending, shear and torsion force
②using Eurocode in a
③RC building
④performing dynamic analysis for earthquake under DCH MRF (Ductility class high moment-resisting frames)An example from other software (sorry to attached here but it is the best example that what we need) the output and check that we need please:Thanks in advance for your answer and sorry to make this new message, but we are very interested and it is urgent to know it.Best regards,
Carlos.
Dear Modestas, thanks for your quick response.I am confuse because in the file about STAAD.pro v8.1 updates from 2007 (PDF attached, chapter 5, AD.2007-05.1.4 Eurocode 8) it shows that you can choose ductility level parameters (but only for UK Annex) doing "Seismic Design and Detailing per EC8". To summarize from your comment, to use full Seismic Design and Detailing for RC and Steel building (under EC8) we need RCDC (inside STAAD.Rpo advanced), right?Best regards,
PDF
"Seismic Design and Detailing per EC8" was available in the RC Designer module, which was available in STAAD.Pro V8i. STAAD.Pro V8i is an old generation of STAAD.Pro which is neither developed nor supported anymore and we do not recommend in using it. However, if you still decide to use the RC Designer in STAAD.Pro V8i, then there is no license required to use that module as far as I remember.
The RC Designer was changed by Advanced Concrete Design workflow (RCDC) in STAAD.Pro CE which we recommend to use. The RCDC requires STAAD.Pro Advanced license to use it in full capabilities.
Dear Sir,The ratio of design moment / Capacity moment is available for following,1. Column design2. Beam design with axial and biaxial moments.The ratio of design axial force/ Axial Capacity is available for following,1. Column designRCDC doesn't show the ratio for Design shear / capacity shear for any element.
We would request you to go through the detailed design calculation report available in RCDC.
Dear Modestas and Abhijeet Gundaye, thanks so much for your replies. I appreciate it. I found my answer about ductility using RCDC checking this manual obtained by STAAD Support assistance by Shreyanka Bhattacharjee.Euro Code Design in RCDC - RAM | STAAD Files - RAM | STAAD - Bentley Communities
