Hi Seth,
In my RAM model error regarding section cuts are coming continuously.
As I need custom load combs.
Can you look into it?
In one model this type of error is coming for two particular locations.
I have sent you with a file name, pnautiyal@miyamotointernational
Though everything appeared to be aligned, I was able to resolve it by adding grids, aligning to the wall ends to grids and then adjusting the grid over 1' and finally back. Regretfully this resets the WDG and section cut assignments. I'll send you the file I have edited, though it needs to be rerun for the right lateral loads and as well as resetting the WDG and section cuts for a few walls.
Thank you Seth for your efforts. Can you just elaborate that why this error is there?? It would highly appreciable if you can write the steps to remove this error?
Ancient polygon routines in the program that break down with small tolerances. The steps were to:
1. Add grid intersections at wall ends.
2. Move grid over (1' for example). Confirm all walls move with grids.
3. Move it back.
Can you just send me the updated model, on which you tried?
Can you please explain that when I move grid by 1' then all framing is getting twisted. How to move grids without affecting the framing?
Thank you Seth, the steps you have provided, that helped me to rectify that error.
