Hi Seth,
In my RAM model error regarding section cuts are coming continuously.
As I need custom load combs.
Can you look into it?
I have already tried that and its not working. I have deleted those walls and added as solid walls so it worked. But it is not working with openings.
If you want to send the file I might be able to help, or log a service request: https://apps.bentley.com/srmanager/ProductSupport
I have sent you with a file name, pnautiyal@miyamotointernational
Though everything appeared to be aligned, I was able to resolve it by adding grids, aligning to the wall ends to grids and then adjusting the grid over 1' and finally back. Regretfully this resets the WDG and section cut assignments. I'll send you the file I have edited, though it needs to be rerun for the right lateral loads and as well as resetting the WDG and section cuts for a few walls.
Thank you Seth for your efforts. Can you just elaborate that why this error is there?? It would highly appreciable if you can write the steps to remove this error?
