Ram Structural System with Ram Concept - LLR Parameters
So I am entering the LLR Parameters manually in a 3 over 1 Podium building and am trying to get the Live Load reduction to work.  On my job, I have (3) levels, so I thought if I input an area for one level, and then input the total number of levels, that the program would then do the live load reduction based on 3 times the input area.  I just went through the latitude design strips, and input the area of each design strips (taken directly from a plan where "Visible Objects:LLR Parameters" is turned on).  I input that area in both the Trib Area and Influence Area values on the LLR tab of the design strip settings dialog.  I then input the number of levels as 3.  The 'LLR Levels' didn't appear to make any changes to how the program calculated the LLR.
As an example, 1 bay of a continuous design strip that I have has LLR Parameters area of 681 sf.  It is roughly 28'-0" long by 24'-0" wide so that area appears correct.  I have the LLR Calculations set to the 2018 IBC.  I went through and input manually that the "LLR Levels" = 3 and the Trib Area = 681 sf, and the program calculates a 17.5% reduction.  This 17.5% reduction is what you would calculate by IBC 2018 Equation 16-23 for a 681 square foot area and a Kll = 1.0 for a two way slab.
I thought the whole reason to have the LLR Levels input was so I wouldn't have to calculate by hand the area is 3 times the area that I input (when you have dozens of bays in two directions, and you are inputting the areas manually, adding a calculation to it would be even more cumbersome).  So what is the point of the LLR Levels line?  What am I doing wrong?
Parents Reply Children
