Brought this issue up previously but wanted to see if anyone else is having the same issue. Figured it'd be worth posting on here just in case.
We’ve had a few cases in our office with folks who have upgraded to the most recent RAM Elements version trying to open past projects. It appears that the issue results when trying to run an “old” file that was created in a previous version. My understanding is that the analysis will sometimes return an error due to an instability at a node (as is common). The issue lies in the fact that the noted node/instability does not impact the error result. For example it’ll return an instability at Node 1 in UX. If you grab Node 1 and fully fix it, it will then return an error at Node 2 in UX (and then Node 3, Node 4, etc). In the past it was easier to “chase” these instabilities around, fixing the errors, rerunning, and then fixing new errors. These errors would correspond to the actual location of the instability, not just a sequential step through the node numbers.
I understand that best practice would be to NOT create a model in the first place that has instabilities. That said, when folks start creating models with hundreds and hundreds of members, they're bound to make some sort of mistake, especially if they're a little newer to the program. Best practices in modeling would obviously be the best starting point, but this issue just makes it a bit more of a scavenger hunt when trying to clean up a model. As noted, in the past (up until this last update), the errors that came up would point you to the actual location of the instability. With the new issue, the default error is simply the first node which makes it really hard to pinpoint the source of your instability.
Any chance we could revert back to how the previous updates handled things, where the error module helped us out a bit by pointing to the location of instability (versus simply using the first node in the stiffness matrix)? Not sure if there is a real downside of that unless I'm missing something.
The sparse solver uses some Intel technology to optimize the matrix and generally offers better performance for large models, but it's a little more sensitive to a 0 diagonal issues.
Gotcha - makes sense. For that reason I guess it would be nice to see if we can figure it out and still use the default (sparse solver). That said, we can play around with some of our models over here and see if changing that to just Direct fixes the issue in other situations or just for this particular one.
