I am unsure where the output is referencing these highlighted below. I don't understand what "Table 4.1a.Case1" or "Cl.E3" references to. The references to Eq. E3-4 are in the appendix of the steel manual. But I can't find the others.
What design code and section are you using? What version?
This looks like an AISC check and if it is, I think the code reference is missing the B. I believe table B4.1 is the slenderness diagrams.
It is AISC 360-16 LRFD, version v16 (16.00.00.37) 64-bit
sbouvia is correct, Table B4.1a
Answer Verified By: Pascual Mauricio
And "Cl.E3" means section E3 in the appendix? Or perhaps controlling load? As in, controlling case in that section?
I think that's just the main Clause E3 from the spec, not the appendix or commentary per se.
