Hopefully, you are doing well.
could you please help me to solve this error? this is the code below.
regards,
DEFINE WIND LOADTYPE 1 WIND -Z (WINDWARD WALL)<! STAAD PRO GENERATED DATA DO NOT MODIFY !!!ASCE-7-2010:PARAMS 137.000 KMPH 0 1 2 0 0.000 FT 0.000 FT 0.000 FT 1 -2 13.814 M 128.470 M 34.577 M 2.000 0.025 0 -0 0 0 0 0.788 1.000 1.000 0.850 0 -0 0 0 0.831 0.800 -0.180!> END GENERATED DATA BLOCKINT 1.02485 1.02485 1.05636 1.08496 1.11124 1.1356 1.15834 1.1797 1.19987 - 1.21899 1.23719 1.25456 1.2712 1.28716 1.30252 1.30218 HEIG 0 4.572 5.28292 - 5.99385 6.70477 7.41569 8.12662 8.83754 9.54846 10.2594 10.9703 - 11.6812 12.3921 13.1031 13.814 13.8139EXP 1 JOINT 1 TO 3 5 7 TO 9 11 13 TO 42 45 TO 48 82 TO 93 104 106 108 TO 127 -130 TO 157 160 TO 185 187 TO 221 224 TO 281 286 TO 289 291 TO 299 -301 TO 305 307 TO 324 326 335 TO 348 351 TO 356 358 TO 362 364 TO 367 369 -370 TO 372 374 TO 377 379 TO 382 384 TO 387 389 390 396 397 399 TO 402 404 -405 TO 407 409 410 415 TO 453 455 TO 464 466 TO 475 477 TO 486 488 TO 519 -530 TO 535 538 TO 541 617 619 TO 631 633 TO 683 685 TO 687 689 TO 691 693 -694 TO 695 697 TO 699 701 TO 703 705 TO 707 716 TO 727 729 TO 747 749 TO 770 -772 TO 789 791 TO 808 810 TO 827 829 TO 855 857 TO 865 867 TO 883 -885 TO 901 903 TO 919 921 TO 938 940 TO 957 959 TO 976 978 TO 995 -997 TO 1014 1016 TO 1033 1035 TO 1052 1054 TO 1071 1073 TO 1090 1092 TO 1116 -1118 1124 1126 1132 TO 1134 1141 1145 1147 1151 1155 1159 1163 1167 1171 -1175 1179 1183 1187 1191 1195 1199 1203 1207 1211 1216 TO 1281 1504 TO 1563 -1584 TO 1613 1746 1750 1757 TO 1759 1768 1769 1771 1772 1781 1782 1785 1788 -1791 1794 1797 1799 1801 TO 1803 1805 1813 TO 1816 1819 TO 1822 1824 TO 1851 -1853 TO 1889 1891 TO 1927 1929 TO 1942TYPE 2 WIND -Z (LEEWARD WALL)<! STAAD PRO GENERATED DATA DO NOT MODIFY !!!ASCE-7-2010:PARAMS 137.000 KMPH 0 1 2 0 0.000 FT 0.000 FT 0.000 FT 1 -2 13.814 M 128.470 M 34.577 M 2.000 0.025 1 -0 0 0 0 0.788 1.000 1.000 0.850 0 -0 0 0 0.831 -0.214 0.180!> END GENERATED DATA BLOCKINT -0.213109 -0.213109 -0.213109 HEIG 0 13.814 13.814EXP 1 JOINT 1 TO 3 5 7 TO 9 11 13 TO 42 45 TO 48 82 TO 93 104 106 108 TO 127 -130 TO 157 160 TO 185 187 TO 221 224 TO 281 286 TO 289 291 TO 299 -301 TO 305 307 TO 324 326 335 TO 348 351 TO 356 358 TO 362 364 TO 367 369 -370 TO 372 374 TO 377 379 TO 382 384 TO 387 389 390 396 397 399 TO 402 404 -405 TO 407 409 410 415 TO 453 455 TO 464 466 TO 475 477 TO 486 488 TO 519 -530 TO 535 538 TO 541 617 619 TO 631 633 TO 683 685 TO 687 689 TO 691 693 -694 TO 695 697 TO 699 701 TO 703 705 TO 707 716 TO 727 729 TO 747 749 TO 770 -772 TO 789 791 TO 808 810 TO 827 829 TO 855 857 TO 865 867 TO 883 -885 TO 901 903 TO 919 921 TO 938 940 TO 957 959 TO 976 978 TO 995 -997 TO 1014 1016 TO 1033 1035 TO 1052 1054 TO 1071 1073 TO 1090 1092 TO 1116 -1118 1124 1126 1132 TO 1134 1141 1145 1147 1151 1155 1159 1163 1167 1171 -1175 1179 1183 1187 1191 1195 1199 1203 1207 1211 1216 TO 1281 1504 TO 1563 -1584 TO 1613 1746 1750 1757 TO 1759 1768 1769 1771 1772 1781 1782 1785 1788 -1791 1794 1797 1799 1801 TO 1803 1805 1813 TO 1816 1819 TO 1822 1824 TO 1851 -1853 TO 1889 1891 TO 1927 1929 TO 1942TYPE 3 WIND -Z(SIDE WALL)<! STAAD PRO GENERATED DATA DO NOT MODIFY !!!ASCE-7-2010:PARAMS 137.000 KMPH 0 1 2 0 0.000 FT 0.000 FT 0.000 FT 1 -2 13.814 M 128.470 M 34.577 M 2.000 0.025 2 -0 0 0 0 0.788 1.000 1.000 0.850 0 -0 0 0 0.831 -0.700 0.180!> END GENERATED DATA BLOCKINT -0.453434 -0.453434 HEIG 0 13.814EXP 1 JOINT 1 TO 3 5 7 TO 9 11 13 TO 42 45 TO 48 82 TO 93 104 106 108 TO 127 -130 TO 157 160 TO 185 187 TO 221 224 TO 281 286 TO 289 291 TO 299 -301 TO 305 307 TO 324 326 335 TO 348 351 TO 356 358 TO 362 364 TO 367 369 -370 TO 372 374 TO 377 379 TO 382 384 TO 387 389 390 396 397 399 TO 402 404 -405 TO 407 409 410 415 TO 453 455 TO 464 466 TO 475 477 TO 486 488 TO 519 -530 TO 535 538 TO 541 617 619 TO 631 633 TO 683 685 TO 687 689 TO 691 693 -694 TO 695 697 TO 699 701 TO 703 705 TO 707 716 TO 727 729 TO 747 749 TO 770 -772 TO 789 791 TO 808 810 TO 827 829 TO 855 857 TO 865 867 TO 883 -885 TO 901 903 TO 919 921 TO 938 940 TO 957 959 TO 976 978 TO 995 -997 TO 1014 1016 TO 1033 1035 TO 1052 1054 TO 1071 1073 TO 1090 1092 TO 1116 -1118 1124 1126 1132 TO 1134 1141 1145 1147 1151 1155 1159 1163 1167 1171 -1175 1179 1183 1187 1191 1195 1199 1203 1207 1211 1216 TO 1281 1504 TO 1563 -1584 TO 1613 1746 1750 1757 TO 1759 1768 1769 1771 1772 1781 1782 1785 1788 -1791 1794 1797 1799 1801 TO 1803 1805 1813 TO 1816 1819 TO 1822 1824 TO 1851 -1853 TO 1889 1891 TO 1927 1929 TO 1942TYPE 4 WIND X(WINDWARD WALL)<! STAAD PRO GENERATED DATA DO NOT MODIFY !!!ASCE-7-2010:PARAMS 137.000 KMPH 0 1 2 0 0.000 FT 0.000 FT 0.000 FT 1 -2 13.814 M 34.577 M 128.470 M 2.000 0.025 0 -0 0 0 0 0.788 1.000 1.000 0.850 0 -0 0 0 0.773 0.800 -0.180!> END GENERATED DATA BLOCKINT 0.375422 0.375422 0.386733 0.397003 0.406437 0.415181 0.423344 0.431013 - 0.438252 0.445117 0.451649 0.457886 0.463857 0.469588 0.475101 HEIG 0 4.572 - 5.28292 5.99385 6.70477 7.41569 8.12662 8.83754 9.54846 10.2594 - 10.9703 11.6812 12.3921 13.1031 13.814EXP 1 JOINT 1 TO 3 5 7 TO 9 11 13 TO 42 45 TO 48 82 TO 93 104 106 108 TO 127 -130 TO 157 160 TO 185 187 TO 221 224 TO 281 286 TO 289 291 TO 299 -301 TO 305 307 TO 324 326 335 TO 348 351 TO 356 358 TO 362 364 TO 367 369 -370 TO 372 374 TO 377 379 TO 382 384 TO 387 389 390 396 397 399 TO 402 404 -405 TO 407 409 410 415 TO 453 455 TO 464 466 TO 475 477 TO 486 488 TO 519 -530 TO 535 538 TO 541 617 619 TO 631 633 TO 683 685 TO 687 689 TO 691 693 -694 TO 695 697 TO 699 701 TO 703 705 TO 707 716 TO 727 729 TO 747 749 TO 770 -772 TO 789 791 TO 808 810 TO 827 829 TO 855 857 TO 865 867 TO 883 -885 TO 901 903 TO 919 921 TO 938 940 TO 957 959 TO 976 978 TO 995 -997 TO 1014 1016 TO 1033 1035 TO 1052 1054 TO 1071 1073 TO 1090 1092 TO 1116 -1118 1124 1126 1132 TO 1134 1141 1145 1147 1151 1155 1159 1163 1167 1171 -1175 1179 1183 1187 1191 1195 1199 1203 1207 1211 1216 TO 1281 1504 TO 1563 -1584 TO 1613 1746 1750 1757 TO 1759 1768 1769 1771 1772 1781 1782 1785 1788 -1791 1794 1797 1799 1801 TO 1803 1805 1813 TO 1816 1819 TO 1822 1824 TO 1851 -1853 TO 1889 1891 TO 1927 1929 TO 1942TYPE 5 WIND X(LEEWARD WALL)<! STAAD PRO GENERATED DATA DO NOT MODIFY !!!ASCE-7-2010:PARAMS 137.000 KMPH 0 1 2 0 0.000 FT 0.000 FT 0.000 FT 1 -2 13.814 M 34.577 M 128.470 M 2.000 0.025 1 -0 0 0 0 0.788 1.000 1.000 0.850 0 -0 0 0 0.773 -0.500 0.180!> END GENERATED DATA BLOCKINT -0.33711 -0.33711 HEIG 0 13.814EXP 1 JOINT 1 TO 3 5 7 TO 9 11 13 TO 42 45 TO 48 82 TO 93 104 106 108 TO 127 -130 TO 157 160 TO 185 187 TO 221 224 TO 281 286 TO 289 291 TO 299 -301 TO 305 307 TO 324 326 335 TO 348 351 TO 356 358 TO 362 364 TO 367 369 -370 TO 372 374 TO 377 379 TO 382 384 TO 387 389 390 396 397 399 TO 402 404 -405 TO 407 409 410 415 TO 453 455 TO 464 466 TO 475 477 TO 486 488 TO 519 -530 TO 535 538 TO 541 617 619 TO 631 633 TO 683 685 TO 687 689 TO 691 693 -694 TO 695 697 TO 699 701 TO 703 705 TO 707 716 TO 727 729 TO 747 749 TO 770 -772 TO 789 791 TO 808 810 TO 827 829 TO 855 857 TO 865 867 TO 883 -885 TO 901 903 TO 919 921 TO 938 940 TO 957 959 TO 976 978 TO 995 -997 TO 1014 1016 TO 1033 1035 TO 1052 1054 TO 1071 1073 TO 1090 1092 TO 1116 -1118 1124 1126 1132 TO 1134 1141 1145 1147 1151 1155 1159 1163 1167 1171 -1175 1179 1183 1187 1191 1195 1199 1203 1207 1211 1216 TO 1281 1504 TO 1563 -1584 TO 1613 1746 1750 1757 TO 1759 1768 1769 1771 1772 1781 1782 1785 1788 -1791 1794 1797 1799 1801 TO 1803 1805 1813 TO 1816 1819 TO 1822 1824 TO 1851 -1853 TO 1889 1891 TO 1927 1929 TO 1942TYPE 6 WIND X(SIDE WALL)<! STAAD PRO GENERATED DATA DO NOT MODIFY !!!ASCE-7-2010:PARAMS 137.000 KMPH 0 1 2 0 0.000 FT 0.000 FT 0.000 FT 1 -2 13.814 M 34.577 M 128.470 M 2.000 0.025 2 -0 0 0 0 0.788 1.000 1.000 0.850 0 -0 0 0 0.773 -0.700 0.180!> END GENERATED DATA BLOCKINT -0.429104 -0.429104 HEIG 0 13.814EXP 1 JOINT 1 TO 3 5 7 TO 9 11 13 TO 42 45 TO 48 82 TO 93 104 106 108 TO 127 -130 TO 157 160 TO 185 187 TO 221 224 TO 281 286 TO 289 291 TO 299 -301 TO 305 307 TO 324 326 335 TO 348 351 TO 356 358 TO 362 364 TO 367 369 -370 TO 372 374 TO 377 379 TO 382 384 TO 387 389 390 396 397 399 TO 402 404 -405 TO 407 409 410 415 TO 453 455 TO 464 466 TO 475 477 TO 486 488 TO 519 -530 TO 535 538 TO 541 617 619 TO 631 633 TO 683 685 TO 687 689 TO 691 693 -694 TO 695 697 TO 699 701 TO 703 705 TO 707 716 TO 727 729 TO 747 749 TO 770 -772 TO 789 791 TO 808 810 TO 827 829 TO 855 857 TO 865 867 TO 883 -885 TO 901 903 TO 919 921 TO 938 940 TO 957 959 TO 976 978 TO 995 -997 TO 1014 1016 TO 1033 1035 TO 1052 1054 TO 1071 1073 TO 1090 1092 TO 1116 -1118 1124 1126 1132 TO 1134 1141 1145 1147 1151 1155 1159 1163 1167 1171 -1175 1179 1183 1187 1191 1195 1199 1203 1207 1211 1216 TO 1281 1504 TO 1563 -1584 TO 1613 1746 1750 1757 TO 1759 1768 1769 1771 1772 1781 1782 1785 1788 -1791 1794 1797 1799 1801 TO 1803 1805 1813 TO 1816 1819 TO 1822 1824 TO 1851 -1853 TO 1889 1891 TO 1927 1929 TO 1942LOAD 1 LOADTYPE Dead TITLE DEAD LOADONEWAY LOADYRANGE 6.85 6.85 ONE -5.75 XRANGE 0 76.725 ZRANGE 0 17.289 GYSELFWEIGHT Y -1 FLOOR LOADYRANGE 10.45 10.45 FLOAD -5.75 GYONEWAY LOADYRANGE 0 6.85 ONE -5.75 XRANGE 69.025 128.47 ZRANGE 23.777 34.576 GYMEMBER LOAD4152 UNI GY -4.1431648 1689 TO 1700 1702 TO 1704 1706 TO 1708 2475 TO 2477 2484 2487 2504 2505 -3689 3716 3719 3722 UNI GY -0.563441 1650 1652 1654 1656 1749 TO 1760 1762 TO 1773 1775 TO 1779 1781 TO 1783 -1785 TO 1792 1794 TO 1798 1800 TO 1802 1804 TO 1811 1813 TO 1817 -1819 TO 1821 1823 1824 2429 TO 2432 2500 2506 2507 2515 TO 2517 2532 2533 -2547 TO 2549 3669 3673 4169 4170 4172 4176 4180 4182 4185 4187 4191 4194 -4202 4204 UNI GY -1.1251657 1658 1825 1827 TO 1829 1831 TO 1839 1841 TO 1843 2564 2565 3677 4192 -4198 4208 4628 UNI GY -1.171661 1663 1844 TO 1854 1856 TO 1858 1860 TO 1872 1874 TO 1876 1878 1879 2579 -2580 TO 2581 2595 TO 2597 3679 3681 4212 4213 4626 UNI GY -1.221665 1880 TO 1890 1892 TO 1894 1896 1897 2611 TO 2613 3683 4229 -4627 UNI GY -1.151667 1668 1898 TO 1908 1910 TO 1912 1914 TO 1916 2627 TO 2629 3685 -4228 UNI GY -1.111670 1917 TO 1928 1930 TO 1932 1934 1935 2433 2631 TO 2633 3687 -4242 UNI GY -1.031672 1936 TO 1947 1949 TO 1951 1953 1954 2434 2659 TO 2661 3691 -4243 UNI GY -0.871674 1676 1955 TO 1966 1968 TO 1970 1972 TO 1985 1987 TO 1989 1991 TO 2004 -2006 TO 2008 2010 TO 2023 2025 TO 2027 2029 2030 2435 TO 2438 2663 TO 2665 -2667 TO 2669 2683 TO 2685 2699 TO 2701 3693 3695 3697 3699 4256 4257 4281 -4285 4288 4290 4292 4294 UNI GY -0.841682 2031 TO 2042 2044 TO 2046 2048 2049 2439 2715 TO 2717 3701 4302 -4303 UNI GY -1.031684 2050 TO 2061 2063 TO 2065 2067 2068 2440 2731 TO 2733 3703 4304 -4305 UNI GY -0.971686 2069 TO 2080 2082 TO 2084 2086 2087 2441 2747 TO 2749 3705 4319 -4320 UNI GY -0.7221688 1709 TO 1720 1722 TO 1724 1726 TO 1728 2456 2457 2465 2466 2468 2469 -2750 2751 3707 3747 3753 UNI GY -0.361ONEWAY LOADYRANGE 6.85 6.85 ONE -5.75 XRANGE 0 37.5 ZRANGE 23.777 34.577 GYYRANGE 6.85 6.85 ONE -5.75 XRANGE 37.5 69.025 ZRANGE 23.777 31.376 GYYRANGE 6.85 6.85 ONE -5.75 XRANGE 69.025 76.725 ZRANGE 17.289 23.777 GYLOAD 2 LOADTYPE Live TITLE LIVE LOADONEWAY LOADYRANGE 6.85 6.85 ONE -9 XRANGE 0 76.725 ZRANGE 0 17.289 GYFLOOR LOADYRANGE 10.45 10.45 FLOAD -2 GYONEWAY LOADYRANGE 0 6.85 ONE -9 XRANGE 76.725 128.47 ZRANGE 23.777 34.576 GYMEMBER LOAD4152 UNI GY -6.481648 1689 TO 1700 1702 TO 1704 1706 TO 1708 2475 TO 2477 2484 2487 2504 2505 -3689 3716 3719 3722 UNI GY -3.75441 1650 1652 1654 1656 1749 TO 1760 1762 TO 1773 1775 TO 1779 1781 TO 1783 -1785 TO 1792 1794 TO 1798 1800 TO 1802 1804 TO 1811 1813 TO 1817 -1819 TO 1821 1823 1824 2429 TO 2432 2500 2506 2507 2515 TO 2517 2532 2533 -2547 TO 2549 3669 3673 4169 4170 4172 4176 4180 4182 4185 4187 4191 4194 -4202 4204 UNI GY -7.51657 1658 1825 1827 TO 1829 1831 TO 1839 1841 TO 1843 2564 2565 3677 4192 -4198 4208 4628 UNI GY -7.8131661 1663 1844 TO 1854 1856 TO 1858 1860 TO 1872 1874 TO 1876 1878 1879 2579 -2580 TO 2581 2595 TO 2597 3679 3681 4212 4213 4626 UNI GY -8.1251665 1880 TO 1890 1892 TO 1894 1896 1897 2611 TO 2613 3683 4229 -4627 UNI GY -7.641667 1668 1898 TO 1908 1910 TO 1912 1914 TO 1916 2627 TO 2629 3685 -4228 UNI GY -7.4251670 1917 TO 1928 1930 TO 1932 1934 1935 2433 2631 TO 2633 3687 -4242 UNI GY -6.851672 1936 TO 1947 1949 TO 1951 1953 1954 2434 2659 TO 2661 3691 -4243 UNI GY -5.81674 1676 1955 TO 1966 1968 TO 1970 1972 TO 1985 1987 TO 1989 1991 TO 2004 -2006 TO 2008 2010 TO 2023 2025 TO 2027 2029 2030 2435 TO 2438 2663 TO 2665 -2667 TO 2669 2683 TO 2685 2699 TO 2701 3693 3695 3697 3699 4256 4257 4281 -4285 4288 4290 4292 4294 UNI GY -5.61682 2031 TO 2042 2044 TO 2046 2048 2049 2439 2715 TO 2717 3701 4302 -4303 UNI GY -6.8631684 2050 TO 2061 2063 TO 2065 2067 2068 2440 2731 TO 2733 3703 4304 -4305 UNI GY -6.471686 2069 TO 2080 2082 TO 2084 2086 2087 2441 2747 TO 2749 3705 4319 -4320 UNI GY -4.811688 1709 TO 1720 1722 TO 1724 1726 TO 1728 2456 2457 2465 2466 2468 2469 -2750 2751 3707 3747 3753 UNI GY -2.41ONEWAY LOADYRANGE 6.85 6.85 ONE -9 XRANGE 0 37.5 ZRANGE 23.777 34.577 GYYRANGE 6.85 6.85 ONE -9 XRANGE 37.5 69.025 ZRANGE 23.777 31.376 GYYRANGE 6.85 6.85 ONE -9 XRANGE 69.025 76.725 ZRANGE 17.289 34.576 GYLOAD 3 LOADTYPE Wind TITLE WIND IN -ZWIND LOAD Z -1 TYPE 1 YR 0 13.8139WIND LOAD -Z -1 TYPE 2 YR 0 13.814WIND LOAD -X -1 TYPE 3 YR 0 13.814WIND LOAD -X 1 TYPE 3 YR 0 13.814LOAD 4 LOADTYPE Wind TITLE WIND IN XWIND LOAD X 1 TYPE 4 YR 0 13.814WIND LOAD -X 1 TYPE 5 YR 0 13.814WIND LOAD -Z 1 TYPE 6 YR 0 13.814WIND LOAD -Z -1 TYPE 6 YR 0 13.814LOAD 5 LOADTYPE Wind TITLE WIND IN ZWIND LOAD Z 1 TYPE 1 YR 0 13.814WIND LOAD -Z 1 TYPE 2 YR 0 13.814WIND LOAD -X 1 TYPE 3 YR 0 13.814WIND LOAD -X -1 TYPE 3 YR 0 13.814LOAD 6 LOADTYPE Wind TITLE WIND IN -XWIND LOAD X -1 TYPE 4 YR 0 13.814WIND LOAD -X -1 TYPE 5 YR 0 13.814WIND LOAD -Z -1 TYPE 6 YR 0 13.814WIND LOAD -Z 1 TYPE 6 YR 0 13.814LOAD COMB 11 GENERATED AISC GENERAL 11 1.0 LOAD COMB 12 GENERATED AISC GENERAL 21 1.0 2 1.0 LOAD COMB 13 GENERATED AISC GENERAL 31 1.0 2 0.75 LOAD COMB 14 GENERATED AISC GENERAL 41 1.0 3 1.0 LOAD COMB 15 GENERATED AISC GENERAL 51 1.0 4 1.0 LOAD COMB 16 GENERATED AISC GENERAL 61 1.0 5 1.0 LOAD COMB 17 GENERATED AISC GENERAL 71 1.0 6 1.0 LOAD COMB 18 GENERATED AISC GENERAL 81 1.0 2 0.75 3 0.75 LOAD COMB 19 GENERATED AISC GENERAL 91 1.0 2 0.75 4 0.75 LOAD COMB 20 GENERATED AISC GENERAL 101 1.0 2 0.75 5 0.75 LOAD COMB 21 GENERATED AISC GENERAL 111 1.0 2 0.75 6 0.75 LOAD COMB 22 GENERATED AISC GENERAL 121 0.6 3 1.0 LOAD COMB 23 GENERATED AISC GENERAL 131 0.6 4 1.0 LOAD COMB 24 GENERATED AISC GENERAL 141 0.6 5 1.0 LOAD COMB 25 GENERATED AISC GENERAL 151 0.6 6 1.0 LOAD COMB 26 GENERATED AISC GENERAL 161 0.6 DEFINE ENVELOPE11 TO 26 ENVELOPE 1END DEFINE ENVELOPEPERFORM ANALYSIS
Please refer below link.
https://communities.bentley.com/products/ram-staad/f/ram-staad-forum/228202/i-faced-this-error-please-could-you-help-me-to-solve-this-problem
