This is my first time using a RAM model and I have run into an error when trying to layout my building. All of my columns go in correctly except for one area where I get the error "unable to add column. column would overlap another column. There is no other column in the specified location in my model. There are columns at the same grid point below this point, but that is the case for all the other columns that do work as well. I would very much appreciate any help. Thanks.
Can you pass us the model please?
Venables Memorial Hotel-Rework.rss
The error is occurring on the Roof and Third Floor layouts
I don't know how this model started (was it imported?), but there are currently 39 columns coincidentally modeled in the lower left corner, Grid A-4. Delete those with a fence, then model a single column at the grid intersection, and that should correct things. You might want to renumber the model too.
