RAM Structural System - BRBF Baseplate Design
Working on a steel project in which we're using CoreBrace BRBFs for a portion of our lateral system. We've gone through the first part of our lateral analysis and have received a table of values (including overstrength parameters) back from CoreBrace. Using these overstrength parameters, we've been able to update the RAM SS model to accurately model the forces that are seen by the buckling restrained braces. Similarly, the seismic provisions design allows us to fully design the columns in the frames for the expected forces that will be delivered by the BRBs as well. All is well in the world.
One question I do have is if RAM SS will allow for design of the column baseplates at the bottom of the BRBF columns. Knowing that the gussets themselves will be in CoreBrace's court, it still seems like it would be useful if RAM SS would allow us to design the baseplate and anchorage "in house" rather than bookkeeping to transfer these loads to another program. It seems like we already have the design tension and could pull the design shear (from the expected brace force). That said, is there a way to do this design in the RAM SS connection module?
