How should I turn on Staad.beava (bridge code) in staad pro connect edition?
In the earlier version, it was easily accessible right at the startup menu as per the screenshot attached.
Please reply.
STAAD.Beava is no longer being a part of STAAD.Pro Connect Edition (CE) now. You may wish to use Bridge Deck workflow. it has the same functionality..
Answer Verified By: Sajal Shrivastava
In case you are unable to locate the option suggested by Bikash, please check the option from workflows.
(2) Bridge Deck is available in the list of Workflow. - RAM | STAAD Wiki - RAM | STAAD - Bentley Communities
