The beam is failing even if i increase the depth of the beam in Mat foundation, i need your help what is the way forward, the results displayed is
"Beam is failing in shear please increase maximum secondary reinforcement"
iam using Staad Advanced Foundation V9 Update 6.1
WING B_foundation.sfa
Have you tried increasing the secondary reinforcement sizes as suggested by the program? Try a maximum stirrup size of 22 and see if that helps.
These are the bar sizes or bar numbers as per ASTM standards. In this case, #10 corresponds to a bar diameter of 9.5mm and #13 corresponds to a bar diameter of 12.7mm. Refer to the ASTM bar charts for details.
Iam using SFA for Staad Pro Update 8,the beam force which is reported at the bottom part of the software
Answer Verified By: Joseph Lucas Magare
Thank you for clarification i usually use BS code,but when it comes to design of footing with beam i decided to use american code as SFA is supporting design of the beam by using American code.I tried to google but what iam getting is the other presentation from what software considers.
May you please help me with that chart
And also the beams are still failing even if i increase the size of reinforcement or the depth and width
I tried to check bar conversion to metric bar, i found this but bar No 6 is not available.What is the size of bar no 6 as is provided in beam as stirrup in SFA
