I changed some member properties and point loads in an existing STAAD project built using the physical modeler. I then clicked "Analytical Modeling" button and switched to the analytical model. There I built in design parameters and commands. Then I ran the analysis to make sure I had no failing members. Switching back to the physical modeler seems to cause no problems and everything looks correct. But when I then try to return to the analytical model, it gets to about 50% when the "Error during Analytical Model Creation" pop up window appears. The details of this error says: Guid should contain 32 digits with 4 dashes (xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx).
I don't understand what is happening and it makes me question the results that I was able to obtain.
Please help.
Hello Brian,Can you send us the STD and STDP (input file for Analytical and Physical models respectively) please?
Hello Bikash,
Thank you for reaching out. The files requested are attached. Hermosa RapiSand Tank.STDHermosa RapiSand Tank.stdp
Hello Brian,
With the attached model I was not getting any such error. I am using the latest version 22.10.00.153. can you please confirm the version you are using? If possible try with the latest version and let us know the outcome.
