<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>Results view by property not working</title><link>https://communities.bentley.com/products/ram-staad/f/ram-staad-forum/229046/results-view-by-property-not-working</link><description>Hi,
 In the post processing tab-&amp;gt; beam results-&amp;gt; utilization ratio, when I try to view the results by property using results setup dialog the filtered results do not show up. Can you please advise?
 Version used: STAAD Pro. Connect Edition Update 8</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: Results view by property not working</title><link>https://communities.bentley.com/thread/708860?ContentTypeID=1</link><pubDate>Wed, 27 Apr 2022 14:39:20 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:1b332868-e9d2-48f0-84bf-5b30a8e40e81</guid><dc:creator>Modestas</dc:creator><description>&lt;p&gt;Are you going to Results -&amp;gt; Select Load Case -&amp;gt; Range -&amp;gt; Property to select the required sections? This process seems to be working fine in the current STAAD.Pro CE version 22.10.00.153. If you are not using this version yet, try to upgrade and see if that works.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
