I am doing an inclined ramp design in STAAD.Is it possible to provide vehicle definition on inclined ramp?
Also, Is it possible to combine the generated loadcases with other primary loadcases like dead & wind?
Inclined load creation can be done using the below option.
You can use the below option to add some predefined load case.
Please note you can add only one load case here.
Answer Verified By: Sharat Chand
Please refer to the attached example-
Movig Load_Vertical.STD
You can use STAAD editor to create load combinations where generated moving loads are a part of them.
