Dear Colleagues, i've upgraded to STAAD.Pro CONNECT Edition - Version 22.09.00.115 and noticed (1) while copy-pasting the structure if triangular plates are involved the preview/selection interface shows distorted model, however if the triangular plates are not selected the previewer shows proper view - however in both the cases the final 'pasted' structure is not distorted, thankfully.
3580.sample.std (Views & STAAD file attached)
(2) not sure if anyone had raised this before but, the way that the Global axis (in the main GUI) rotates while compared with that of the Axis inside this 'specify reference point' (interface while copy-pasting) is not the same... (i.e) in the main GUI when the 'right' arrow key is pressed the structure is rotated clockwise and so is the main Axis in the bottom left corner. BUT inside the 'specify reference point' dialog box window, when the 'right' arrow key is pressed the structure is rotated counter-clockwise while the axis within that window rotates opposite (i.e) clockwise
I checked the first issue in the latest version 22.10.00.153 and could not find it. Seems like it has been fixed already. Can you please upgrade the version and check the issue.
Regarding the second one I could duplicate the issue. I will investigate the cause and get back to you.
Answer Verified By: Dani Paul
Abhisek M said:I checked the first issue in the latest version 22.10.00.153 and could not find it. Seems like it has been fixed already. Can you please upgrade the version and check the issue.
Thanks Abhisek, i'll follow up with our IT for the latest version...
