We need to analyze floor vibration for sensitive equipment according to AISC Design Guide 11 2nd Edition. It looks like the FloorVibe integrated in RAM only checks according to the Design Guide 11 1st Edition, is it correct?
A quick look at www.floorvibe.come shows that they have the latest FloorVibe 3.1 that checks for the 2nd Edition of the Design Guide. Should I buy this version from them directly or is there anyway to update FloorVibe 3.1 from RAM?
We will be updating the FloorVibe installed with Ram Steel eventually, but if you need to check something now then you should probably buy a copy of the latest from FloorVibe.com.
Answer Verified By: Kien Nguyen
Thanks Seth for the quick response.
Is Bentley able to provide an estimated release date for this update?
