I am having issues viewing the various icons in RAM Modeler as they appear very small, I am trying to look for display settings for RAM Modeler to Increase the icon sizes.I'd really appreciate any help.
Hi Milan,Answer is 'Yes'. Go to option and find different options related to sizes.See the attachment.Hope this was what you wanted.Thanks,
Hey Bikash,
thanks for the help but i was looking to scale the circled icons below
Hi Milan,That gonna be a Windows operation.Open the display setting and change Size of text, fonts and other items as shown below.Get out of RAM, on computer screen Right Click ->display setting and set up your desired settings.
Hi Milan, I have the same problem. The tip Bikash mentioned did not work on my laptop. Do you know if there is another way to fix this problem?
Are you using a high resolution or 4K monitor? We have an issue in the application where the icons are displayed very small on high resolution or 4K monitors. The icon library needs to be updated to support larger screen resolution. One thing you can try is to change the display resolution of the monitor to be something like 1920x1080 and/or change the scale and layout to be something like 120 or 150%. If reducing the screen resolution and/or changing the scale & layout does not help then trying the keyboard shortcuts (alt + some letter combination) to access any menu item from toolbar can be another alternative that I can think of for now. Please refer the wiki below which has information on this issue on 4K monitors:
RAM Modeler Issues with Remote Desktop - RAM | STAAD | ADINA Wiki - RAM | STAAD | ADINA - Bentley Communities
