Dear Sir/Madam Greetings,
Wrt above subject, i want to know the exact solution for the warning stated by staad pro software analyzing the .std file.
Here i have tried to increase the FU value upto 75, even though the warning remains for majority of the columns.
Im also attaching the .std file also.
Please note that there are errors or warnings about section failure, but how to solve
WARNING: THE COMPRESSIVE AXIAL STRESS IN MEMBER # 195 EXCEEDS
0.08FCK AT SECTION 0.0 MM FOR LOAD # 16 AS PER
CL 6.1 OF IS-13920 2016.
P1_13920.STD
SORRY..... Its FC value of 75000 Kn/M2 and not as stated above....
I am using 22.10.00.153 and could not find any such warnings where it is telling that the compressive axial stress in member exceeds 0.08fck. Could you please tell me the version number? Also, can you please increase the size of columns and check if that helps?
Thanks & regards,
Abhisek M
Global Technical Support
Subscribe Here
Thanks for your quick response.....
Yes sir, i'm using same v22.10.00.153. Okay Sir, i'll increase the columns size and revert to you back...
