Hi!
I have this problem with the STAAD File missing elements when I save the model and reopen it later.
This shows up when I open the file, and clicking Yes shows the warnings about the "Beams #123 is not found in the structure, removed from the list."
Auto-recovery files for the model show the same issue.
A similar thing happened when I tried to finish the analysis without closing STAAD.Pro (without closing the saved file), when I open and edit load designation in Staad Editor elements go missing.
Is there anyone who knows a fix for this? Or experienced the same?Thank you in advance!
Hello, I'm really sorry for this post. I was not aware of the maximum numbers for elements. I was renumbering beams up to 8 digits. Problem solved after remodeling with 6 digits number, below is the reference. Example from 10021001, I instead used 121001. Good day!Maximum model size in STAAD.Pro - RAM | STAAD | ADINA Wiki - RAM | STAAD | ADINA - Bentley Communities
Answer Verified By: Romar Valbarez
Hello Romar,
Glad to know that your issue is solved. This information is also available in the help document for ready reference.
