Hello!
I am currently having a hard time trying to export a revit analytical model to ram elements. I am aware that I need to create an ISM repository and then open that file in RAM elements. However, my issues is that in my case, RAM elements does not give me the option to import an ISM file.
Shouldn't this option exist? I can only see another option which is the "Itwin services", but I can't see any option that allows me to import or sync. an ISM file.
Would really appreciate some help with this, thanks.
Hello Rogelio,
This option has been moved within iTwin option from Version16.4 onwards. See revision history below.
https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/54692/ram-elements-connect-edition-v16-4-release-notes
Now, you can go to iTwin and select Synchronizer option.
Now select the Local option.
It will now ask for the file. Give the path and then proceed. Please see below link for more details of this workflow.
https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/56188/itwin-services-for-engineering-analysis-details
Hope this helps.
Thanks & regards,
Abhisek M
Global Technical Support
Subscribe Here
