staad pro crashes on startup
When I attempt to launch STAAD.pro the program begins start up and then crashes. When I am doing this I am logged into Connection Client and I have checked that the Licenses are active. I have tried trouble shooting the problem with the procedure in the following like but it did not resolve the problem https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/35070/staad-pro-crashes-during-startup
I'm not sure what the next steps should be, please help my project is moving into construction and I need to use STAAD.pro to finish the design and provide construction support.
I already instaled 22.07.00.160 version, three times already and nothing works
I already did on regedit an nothing
I already uninstall C++ versions
I already rename folders on Users an nothing
