I have been given a staadpro model to analyze but it shows warnings. The warning message is that no members are loaded for a one way load generation. This warning is repeated five times.
Please note that depending on the shape of the floor you may have to break up the FLOOR/ONEWAY LOAD into multiple commands. For details please refer to Technical Reference Manual Section 5.32.4.2 Note d and/or "5.32.4.3 Note f.
The above mentioned text in red is also a warning.
Can someone help me fix this problem?
It seems your floor model is irregular in shape and the program is unable to find some closed panels.
You may break the floor in parts and create different groups to define floor load.
You may refer below links for possible solution.
https://communities.bentley.com/products/ram-staad/f/ram-staad-forum/94383/warning-message
https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/7982/eliminate-floor-load-warning
Thanks & regards,
Abhisek M
Global Technical Support
Subscribe Here
thank you!
