OpenStaad GetMemberEndForces
I have an issue with the GetMemberEndForces command and the input of member number and load case number. I try to use a variable of type Variant to use an array to be more efficient. The issue is staad always return a value of 0 for my forces. If a do the exact same code, but i store the value of my member number and load case number in a variable of type Long, it work without issue, but make my macro slower. Is there an issue with the command GetMemberEndForces and variable of type Variant ?
Public Sub UpdateForces()
Dim objSTAAD As Object
Dim ForceConv As Double
Dim LengthConv As Double
Dim activeMember As Variant
Dim LCnumber As Variant
Dim pnResult As Integer
Dim pdForces0(6) As Double, pdForces1(6) As Double
On Error GoTo erreur
Dim DataRange As Variant
Dim Irow As Long
Dim Icol As Integer
DataRange = Range(Range("G16"), Cells(Range("A16").End(xlDown).Row, Range("G9").End(xlToRight).Column)).Value2
activeMember = Worksheets("Axial loads").ListObjects("MemberId").DataBodyRange.Value2
LCnumber = Worksheets("Axial loads").ListObjects("Loadcases").DataBodyRange.Value2
' delete existing tables
Selection.ClearContents
'Calculate conversion factor for force unit
Select Case Range("B6").Value2
Case "N"
ForceConv = 4448.22
Case "kN"
ForceConv = 4.44822
Case "MN"
ForceConv = 4.44822 / 1000
Case "lbf"
ForceConv = 1000
Case "kip"
ForceConv = 1
End Select
'Calculate conversion factor for length unit
Select Case Range("B7").Value2
Case "mm"
LengthConv = 25.4
Case "m"
LengthConv = 0.0254
Case "in"
LengthConv = 1
Case "ft"
LengthConv = 1 / 12
End Select
Select Case ActiveSheet.Name
Case Is = "Axial loads"
For Irow = LBound(DataRange, 1) To UBound(DataRange, 1)
For Icol = LBound(DataRange, 2) To UBound(DataRange, 2)
objSTAAD.OutPut.GetMemberEndForces activeMember(Irow, 1), 0, LCnumber(1, Icol), pdForces0
objSTAAD.OutPut.GetMemberEndForces activeMember(Irow, 1), 1, LCnumber(1, Icol), pdForces1
If pdForces0(0) >= 0 And -pdForces1(0) >= 0 Then
DataRange(Irow, Icol) = ForceConv * Max(pdForces0(0), -pdForces1(0))
Else
DataRange(Irow, Icol) = ForceConv * Min(pdForces0(0), -pdForces1(0))
End If
Next Icol
Next Irow
Range(Range("G16"), Cells(Range("A16").End(xlDown).Row, Range("G9").End(xlToRight).Column)) = DataRange
End Select
GoTo fin
End If
erreur:
MsgBox (Error(Err.Number))
GoTo fin
fin:
Set objSTAAD = Nothing
End Sub
