OpenSTAAD GetUDLLoads
Hi.
I want to get the equally distributed loads on the STAAD model
I used the following method
Dim oLoad As Object = Nothing '= oStaad.Load
Dim arrdir() As Integer
Dim arrForce() As Double
Dim arrD1() As Double
Dim arrD2() As Double
Dim arrD3() As Double
SetLoadActive(5)
GetUDLLoadCount(10)
wkUniLoad = New uniLoad
If ufCnt > 0 Then
ReDim arrdir(ufCnt - 1)
ReDim arrForce(ufCnt - 1)
ReDim arrD1(ufCnt - 1)
ReDim arrD2(ufCnt - 1)
ReDim arrD3(ufCnt - 1)
GetUDLLLoads(curAmemNo, arrdir, arrForce, arrD1, arrD2, arrD3)
Number/force/direction/D2 can be obtained correctly
ufCnt /arrForce/arrdir/arrD2
But
D1/D3
arrD1/arrD3 cannot be obtained correctly
D3 always returns zero
D1 appears to contain the value of D3
Please let me know if you know how to get it correctly.
Thank you
Translated with www.DeepL.com/Translator (free version)
