A019_PX2_Control Room BLDG_R5-23.05.2022.STD
How to resolve the error in staad ********warning : zero spectral acceleration entered for mode 1
and also when i am trying to design beam in Rcdc after auto design it is showing that ************Beam forces not imported ****************
Hello Sachin,
The releases you have used are not correct and due to that your model is having enormous displacement. Please review the releases and change. This will solve the issue. I tested commenting out the below marked releases and the file is working fine.
Also the file can be read in latest version of RCDC 11.03.1.10.
https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/42309/6-release-note
0825.A019_PX2_Control Room BLDG_R5-23.05.2022.STD
DEAR SIR when working in RCDC for design of beam as per IS 456 - 13920........... @lvl 19.400 grp 28, @lvl 14.650 grp 28 , @lvl 9.850 grp 47 beams are failing by increasing the size also it is failing at this floors
I can still see that you have used moment releases to beams which are connected to columns. You need to rectify it. Even I can see moment releases in Columns- can you please check them again?
