I'm designing some built-up columns using equal angle sections and I'm getting some results. Pls can someone check my model if this is correct. I've used the slave-master command to connect the I-beam onto the built-up column. Is this correct as I'm not sure of the results? See below part of my file and some snippets from my CAD model on some of the connections. I look forward to your suggestions.
Thanks.
Built-Up Columns and Gantry Beam.STD
I reviewed your model and did not notice any modeling mistakes with it.
Thank you Modestas
