My log file is as follows. Kindly go through and please help me with the installation process.
[1E6C:2F30][2022-05-24T22:13:50]i001: Burn v3.11.1.2318, Windows v10.0 (Build 19044: Service Pack 0), path: C:\Users\user\AppData\Local\Temp\{EA1D3A65-495F-4A10-97DD-E324D74BDFE2}\.cr\Setup_StaadProx64_22.09.00.115.exe[1E6C:2F30][2022-05-24T22:13:50]i000: Initializing string variable 'BeBundleProductName' to value 'STAAD.Pro CONNECT Edition V22 Update 9'[1E6C:2F30][2022-05-24T22:13:50]i000: Initializing string variable 'InstallDirectory' to value '[ProgramFiles64Folder]Bentley\Engineering\STAAD.Pro CONNECT Edition\'[1E6C:2F30][2022-05-24T22:13:50]i000: Initializing string variable 'SamplesDirectory' to value ''[1E6C:2F30][2022-05-24T22:13:50]i000: Initializing string variable 'LayoutSavePropertyList' to value 'InstallDirectory'[1E6C:2F30][2022-05-24T22:13:50]i000: Initializing string variable 'AddedPackageAvailablePropertyList' to value 'InstallDirectory'[1E6C:2F30][2022-05-24T22:13:50]i000: Initializing string variable 'BentleyClientPackage_DiskSpaceCheckPath' to value '[InstallDirectory]'[1E6C:2F30][2022-05-24T22:13:50]i000: Initializing string variable 'BeBundleCulture' to value 'en'[1E6C:2F30][2022-05-24T22:13:50]i000: Initializing string variable 'StandardPropertyList' to value 'AdminToolsFolder;AppDataFolder;CommonAppDataFolder;CommonFilesFolder;CommonFiles64Folder;CommonFiles6432Folder;ComputerName;Date;DesktopFolder;FavoritesFolder;FontsFolder;LocalAppDataFolder;LogonUser;MyPicturesFolder;PersonalFolder;ProgramFilesFolder;ProgramFiles64Folder;ProgramFiles6432Folder;ProgramMenuFolder;StartMenuFolder;StartupFolder;SystemFolder;TempFolder;TemplateFolder;WindowsFolder;WindowsVolume;'[1E6C:2F30][2022-05-24T22:13:50]i000: Initializing string variable 'LayoutDirectory' to value '[WindowsVolume]BentleyDownloads\[WixBundleName]\'[1E6C:2F30][2022-05-24T22:13:50]i000: Initializing string variable 'ProductsInstalledByBundle' to value 'NoProductList'[1E6C:2F30][2022-05-24T22:13:50]i000: Initializing string variable 'BeBuildType' to value 'Release'[1E6C:2F30][2022-05-24T22:13:50]i000: Initializing string variable 'BeNotBuildType' to value 'Beta'[1E6C:2F30][2022-05-24T22:13:50]i000: Initializing string variable 'BeBundleShortName' to value 'StaadPro'[1E6C:2F30][2022-05-24T22:13:50]i000: Initializing string variable 'BeWin64Bundle' to value 'yes'[1E6C:2F30][2022-05-24T22:13:50]i000: Initializing string variable 'BeIFUseInternalResolver' to value '0'[1E6C:2F30][2022-05-24T22:13:50]i000: Initializing string variable 'BeEulaFileName' to value 'Eula.htm'[1E6C:2F30][2022-05-24T22:13:50]i000: Initializing string variable 'BundleHelpDocument' to value 'STAAD.Pro_Readme.zip'[1E6C:2F30][2022-05-24T22:13:50]i000: Initializing string variable 'BundleHelpDocumentChildHtml' to value 'GUID-066F664B-4FE0-4322-B8ED-F3E6F1121541.html'[1E6C:2F30][2022-05-24T22:13:50]i009: Command Line: '-burn.clean.room=C:\Users\user\Downloads\Setup_StaadProx64_22.09.00.115.exe -burn.filehandle.attached=672 -burn.filehandle.self=560'[1E6C:2F30][2022-05-24T22:13:50]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\user\Downloads\Setup_StaadProx64_22.09.00.115.exe'[1E6C:2F30][2022-05-24T22:13:50]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\Users\user\Downloads\'[1E6C:2F30][2022-05-24T22:13:50]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\user\AppData\Local\Temp\STAAD.Pro_CONNECT_Edition_V22_Update_9_20220524221350.log'[1E6C:2F30][2022-05-24T22:13:50]i052: Condition 'VersionNT >= v6.1' evaluates to true.[1E6C:2F30][2022-05-24T22:13:50]i000: Setting string variable 'WixBundleName' to value 'STAAD.Pro CONNECT Edition V22 Update 9'[1E6C:2F30][2022-05-24T22:13:50]i000: Setting string variable 'WixBundleManufacturer' to value 'Bentley Systems, Incorporated'[1E6C:2F30][2022-05-24T22:13:50]i000: Loading managed bootstrapper application.[1E6C:2F30][2022-05-24T22:13:51]i000: Creating BA thread to run asynchronously.[1E6C:3200][2022-05-24T22:13:51]i000: Setting Culture Info to en[1E6C:3200][2022-05-24T22:13:51]i000: Setting string variable 'BeSelectedLanguage' to value 'en'[1E6C:3200][2022-05-24T22:13:51]i000: Setting string variable 'BeIFMainProcesCommandLineArgs' to value ''[1E6C:3200][2022-05-24T22:13:51]i000: BentleyBundle Version 13.00.00.19[1E6C:3200][2022-05-24T22:13:51]i000: TRY Set TLS 1.2[1E6C:3200][2022-05-24T22:13:51]i000: Setting string variable 'WixExtractedTempFolder' to value 'C:\Users\user\AppData\Local\Temp\{0BD0DD40-C15E-42AF-B6BA-9A4E99F374DE}\.ba'[1E6C:3200][2022-05-24T22:13:51]i000: Setting string variable 'BundleCurrentPath' to value 'C:\Users\user\AppData\Local\Temp\{EA1D3A65-495F-4A10-97DD-E324D74BDFE2}\.cr'[1E6C:3200][2022-05-24T22:13:51]i000: Setting string variable 'WixBundleLayoutDirectory' to value 'C:\Users\user\Downloads\'[1E6C:3200][2022-05-24T22:13:51]e000: Using Layout File : C:\Users\user\AppData\Local\Temp\{0BD0DD40-C15E-42AF-B6BA-9A4E99F374DE}\.ba\Setup.lyt[1E6C:3200][2022-05-24T22:13:51]i000: Setting DotNet472Full InstallLevel to 1[1E6C:3200][2022-05-24T22:13:51]i000: Setting VC14RedistX64 InstallLevel to 1[1E6C:3200][2022-05-24T22:13:51]i000: Setting VC14RedistX86 InstallLevel to 1[1E6C:3200][2022-05-24T22:13:51]i000: Setting BentleyConnectClient InstallLevel to 1[1E6C:3200][2022-05-24T22:13:51]i000: Setting iTwinServicesAddIn InstallLevel to 1[1E6C:3200][2022-05-24T22:13:51]i000: Setting SqlCE35SP2_x86 InstallLevel to 1[1E6C:3200][2022-05-24T22:13:51]i000: Setting SqlCE35SP2_x64 InstallLevel to 1[1E6C:3200][2022-05-24T22:13:51]i000: Setting SpcCatalog InstallLevel to 1[1E6C:3200][2022-05-24T22:13:51]i000: Setting SpcServer InstallLevel to 1[1E6C:3200][2022-05-24T22:13:51]i000: Setting StaadProPackage InstallLevel to 1[1E6C:3200][2022-05-24T22:13:51]i000: Setting string variable 'StaadProPackage.AddLocal' to value 'DefaultFeature,StaadProDesktopShortcut,StaadProShortcuts,StaadProStartMenuShortcut,StaadProSampleModels'[1E6C:3200][2022-05-24T22:13:51]i000: Setting RCDC InstallLevel to 1[1E6C:3200][2022-05-24T22:13:51]i000: Setting VC10RedistX86 InstallLevel to 1[1E6C:3200][2022-05-24T22:13:51]i000: Setting BuildingPlanner InstallLevel to 1[1E6C:3200][2022-05-24T22:13:51]i000: Setting StructuralSynchronizer InstallLevel to 1[1E6C:3200][2022-05-24T22:13:51]i000: Setting STAADFoundationAdvanced_x86 InstallLevel to 1[1E6C:3200][2022-05-24T22:13:51]i000: Setting string variable 'BePrimaryProductName' to value 'STAAD.Pro CONNECT Edition V22 Update 9 (22.09.00.115)'[1E6C:3200][2022-05-24T22:14:03]i000: Running with UI[1E6C:3200][2022-05-24T22:14:03]i000: Display is set to Full[1E6C:3200][2022-05-24T22:14:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/BasicInstallDirectorySelectionUserControl.xaml[1E6C:3200][2022-05-24T22:14:04]i000: Setting string variable 'BeSelectedLanguage' to value ''[1E6C:3200][2022-05-24T22:14:04]i000: Value for WixBundleSourceProcessPath is C:\Users\user\Downloads\Setup_StaadProx64_22.09.00.115.exe[1E6C:3200][2022-05-24T22:14:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/UninstallVerificationUserConstrol.xaml[1E6C:3200][2022-05-24T22:14:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/DeploymentImageSettingsControl.xaml[1E6C:3200][2022-05-24T22:14:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/FeatureConfigUserControl.xaml[1E6C:3200][2022-05-24T22:14:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ProxySettingsUserControl.xaml[1E6C:3200][2022-05-24T22:14:04]i000: Register callbak=ProxySettingsPage[1E6C:3200][2022-05-24T22:14:04]i000: Display Page=ProxySettingsPage[1E6C:3200][2022-05-24T22:14:04]i000: Cannot Display Page=ProxySettingsPage[1E6C:3200][2022-05-24T22:14:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ErrorUserControl.xaml[1E6C:3200][2022-05-24T22:14:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/MaintenanceUserControl.xaml[1E6C:3200][2022-05-24T22:14:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/RepairSelectionUserControl.xaml[1E6C:3200][2022-05-24T22:14:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/AddedPackageUserControl.xaml[1E6C:2F30][2022-05-24T22:14:04]i100: Detect begin, 15 packages[1E6C:2F30][2022-05-24T22:14:04]i000: DetectBegin: e.Install=false, PlannedAction=Unknown, Setting InstallState=DetectedAbsent[1E6C:2F30][2022-05-24T22:14:04]i000: SetCaseIndependentVariable: Check for VaribaleName=BeEmbeddedDisplay[1E6C:2F30][2022-05-24T22:14:04]i000: SetCaseIndependentVariable: Check for VaribaleName=BeEmbeddedDisplay[1E6C:2F30][2022-05-24T22:14:04]i000: SetCaseIndependentVariable: Check for VaribaleName=BeEmbeddedDisplay[1E6C:2F30][2022-05-24T22:14:04]i000: SetCaseIndependentVariable: Check for VaribaleName=SkipPendingSystemRebootCheck[1E6C:2F30][2022-05-24T22:14:04]i000: SetCaseIndependentVariable: Check for VaribaleName=SkipPendingSystemRebootCheck[1E6C:2F30][2022-05-24T22:14:04]i000: SetCaseIndependentVariable: Check for VaribaleName=SkipPendingSystemRebootCheck[1E6C:2F30][2022-05-24T22:14:04]i000: DetectBegin: Installed State of Package DetectedAbsent[1E6C:2F30][2022-05-24T22:14:04]i000: Setting version variable 'ConnectAdvisorInstalledVersion' to value '10.1.0.210'[1E6C:2F30][2022-05-24T22:14:04]i000: Registry key not found. Key = 'SOFTWARE\Bentley\BentleyDesktopClient\Install'[1E6C:2F30][2022-05-24T22:14:04]i000: Product or related product not found: {DEF2AB51-537B-49DB-A263-36EACAF8ABE5}[1E6C:2F30][2022-05-24T22:14:04]i000: Setting version variable 'iTwinServicesAddInInstalledVersion' to value '0.0.0.0'[1E6C:2F30][2022-05-24T22:14:04]i000: Registry key not found. Key = 'SOFTWARE\Bentley\Installed_LanguagePacks\{2CE036A7-3141-4D84-ADF0-8C13CD58F8C1}'[1E6C:2F30][2022-05-24T22:14:04]i000: Setting string variable 'NetFramework4_InstalledVersion' to value '528372'[1E6C:2F30][2022-05-24T22:14:04]i000: Registry key not found. Key = 'SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\DA93DA4DE19033D4BBB2956FCF8BDA3C\InstallProperties'[1E6C:2F30][2022-05-24T22:14:04]i000: Registry key not found. Key = 'SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\D30CF9A3586C138449FCE4FD3D474979\InstallProperties'[1E6C:2F30][2022-05-24T22:14:04]i000: Product or related product not found: {D398D8CF-A4F2-4385-8B8C-648C541046DB}[1E6C:2F30][2022-05-24T22:14:04]i000: Setting version variable 'STAADAdvancedConcreteDesignRCDCVersion' to value '0.0.0.0'[1E6C:2F30][2022-05-24T22:14:04]i000: Product or related product not found: {F52A2A12-4E1F-43FD-8847-914B6C4F2BB3}[1E6C:2F30][2022-05-24T22:14:04]i000: Setting version variable 'STAADFoundationAdvancedInstalledVersion' to value '0.0.0.0'[1E6C:2F30][2022-05-24T22:14:04]i000: Product or related product not found: {74322187-0D4D-4B4E-948B-EF61E96691DA}[1E6C:2F30][2022-05-24T22:14:04]i000: Setting numeric variable 'STAADPro_QAnR_Build_Install_State' to value 2[1E6C:2F30][2022-05-24T22:14:04]i000: Registry key not found. Key = 'SOFTWARE\Bentley\ISM'[1E6C:2F30][2022-05-24T22:14:04]i000: Registry key not found. Key = 'SOFTWARE\Wow6432Node\Microsoft\VisualStudio\10.0\VC\VCRedist\x86'[1E6C:2F30][2022-05-24T22:14:04]i000: Product or related product not found: {36F68A90-239C-34DF-B58C-64B30153CE35}[1E6C:2F30][2022-05-24T22:14:04]i000: Setting version variable 'VCRedist2019x64' to value '0.0.0.0'[1E6C:2F30][2022-05-24T22:14:04]i000: Product or related product not found: {65E5BD06-6392-3027-8C26-853107D3CF1A}[1E6C:2F30][2022-05-24T22:14:04]i000: Setting version variable 'VCRedist2019x86' to value '0.0.0.0'[1E6C:2F30][2022-05-24T22:14:04]i052: Condition 'NetFramework4_InstalledVersion >= 461808' evaluates to true.[1E6C:2F30][2022-05-24T22:14:04]i052: Condition '(VCRedist2019x64 >= v14.28.29334.0)' evaluates to false.[1E6C:2F30][2022-05-24T22:14:04]i052: Condition '(VCRedist2019x86 >= v14.28.29334.0)' evaluates to false.[1E6C:2F30][2022-05-24T22:14:04]i052: Condition '(ConnectClient_InstalledVersion_x64 >= v11.00.04.15)' evaluates to false.[1E6C:2F30][2022-05-24T22:14:04]i052: Condition '(iTwinServicesAddInInstalledVersion >= v02.0.0.111)' evaluates to false.[1E6C:2F30][2022-05-24T22:14:04]i052: Condition '(STAADAdvancedConcreteDesignRCDCVersion >= v11.02.00.200)' evaluates to false.[1E6C:2F30][2022-05-24T22:14:04]i052: Condition '"10.0.40219.1" <= VC10Runtime_InstalledVersion_x86' evaluates to false.[1E6C:2F30][2022-05-24T22:14:04]i052: Condition '(StructuralSynchronizer_InstalledVersion_x64 >= v12.1.1.001)' evaluates to false.[1E6C:2F30][2022-05-24T22:14:04]i052: Condition '(STAADFoundationAdvancedInstalledVersion >= v09.07.00.087)' evaluates to false.[1E6C:2F30][2022-05-24T22:14:04]i101: Detected package: DotNet472Full, state: Present, cached: None[1E6C:2F30][2022-05-24T22:14:04]i101: Detected package: VC14RedistX64, state: Absent, cached: Complete[1E6C:2F30][2022-05-24T22:14:04]i101: Detected package: VC14RedistX86, state: Absent, cached: Complete[1E6C:2F30][2022-05-24T22:14:04]i101: Detected package: BentleyConnectClient, state: Absent, cached: Complete[1E6C:2F30][2022-05-24T22:14:04]i101: Detected package: iTwinServicesAddIn, state: Absent, cached: Complete[1E6C:2F30][2022-05-24T22:14:04]i101: Detected package: SqlCE35SP2_x86, state: Absent, cached: Complete[1E6C:2F30][2022-05-24T22:14:04]i101: Detected package: SqlCE35SP2_x64, state: Absent, cached: Complete[1E6C:2F30][2022-05-24T22:14:04]i101: Detected package: SpcCatalog, state: Absent, cached: Complete[1E6C:2F30][2022-05-24T22:14:04]i101: Detected package: SpcServer, state: Absent, cached: Complete[1E6C:2F30][2022-05-24T22:14:04]i101: Detected package: StaadProPackage, state: Absent, cached: Complete[1E6C:2F30][2022-05-24T22:14:04]i104: Detected package: StaadProPackage, feature: DefaultFeature, state: Absent[1E6C:2F30][2022-05-24T22:14:04]i104: Detected package: StaadProPackage, feature: StaadProDesktopShortcut, state: Absent[1E6C:2F30][2022-05-24T22:14:04]i104: Detected package: StaadProPackage, feature: StaadProShortcuts, state: Absent[1E6C:2F30][2022-05-24T22:14:04]i104: Detected package: StaadProPackage, feature: StaadProStartMenuShortcut, state: Absent[1E6C:2F30][2022-05-24T22:14:04]i104: Detected package: StaadProPackage, feature: StaadProSampleModels, state: Absent[1E6C:2F30][2022-05-24T22:14:04]i101: Detected package: RCDC, state: Absent, cached: None[1E6C:2F30][2022-05-24T22:14:04]i101: Detected package: VC10RedistX86, state: Absent, cached: None[1E6C:2F30][2022-05-24T22:14:04]i101: Detected package: BuildingPlanner, state: Absent, cached: None[1E6C:2F30][2022-05-24T22:14:04]i101: Detected package: StructuralSynchronizer, state: Absent, cached: None[1E6C:2F30][2022-05-24T22:14:04]i101: Detected package: STAADFoundationAdvanced_x86, state: Absent, cached: None[1E6C:2F30][2022-05-24T22:14:04]i000: Detect complete Start[1E6C:2F30][2022-05-24T22:14:04]i000: SessionMutex: Creating new SessionMutex[1E6C:2F30][2022-05-24T22:14:04]i000: SessionMutex: Creating Mutex with Name={f1536c0f-09fc-4a78-8e53-d80eb35d792e}-InstallMutex[1E6C:2F30][2022-05-24T22:14:04]i000: SessionMutex: Created new SessionMutex with IsMutexOwned=True[1E6C:2F30][2022-05-24T22:14:04]i000: Setting string variable 'BeBundleVersion' to value '[WixBundleVersion]'[1E6C:2F30][2022-05-24T22:14:04]i000: Setting string variable 'BeBundleProviderKey' to value '[WixBundleProviderKey]'[1E6C:3200][2022-05-24T22:14:04]i000: ErrorPage Code: 0[1E6C:2F30][2022-05-24T22:14:04]i000: KBDetect: Current action is allowed to executed for KB check. ActionName=Install[1E6C:2F30][2022-05-24T22:14:04]i000: Trying to connect to BUDDI, with NetworkCredentials=NULL. Retry Count = 1. Local Retry Count = 1[1E6C:2F30][2022-05-24T22:14:06]e000: WaitForProxyAuthentication: Waiting for proxy authentication[1E6C:2F30][2022-05-24T22:14:06]i000: Fetch BUDDI Key, RetryCount = 0[1E6C:2F30][2022-05-24T22:14:06]e000: SetHeaders (): Added bootstrapper id in header, {f1536c0f-09fc-4a78-8e53-d80eb35d792e}[1E6C:2F30][2022-05-24T22:14:06]i000: Resolving Buddi Key. Attempt: 1[1E6C:2F30][2022-05-24T22:14:10]i000: BeSkipKBCheck : [1E6C:2F30][2022-05-24T22:14:10]i000: Setting string variable 'BePlannedAction' to value 'Install'[1E6C:2F30][2022-05-24T22:14:10]i000: DotNet472Full AnalyzeFeatureConditions: LaunchAction=Install[1E6C:2F30][2022-05-24T22:14:10]i000: DotNet472Full AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[1E6C:2F30][2022-05-24T22:14:10]i000: DotNet472Full AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[1E6C:2F30][2022-05-24T22:14:10]i000: VC14RedistX64 AnalyzeFeatureConditions: LaunchAction=Install[1E6C:2F30][2022-05-24T22:14:10]i000: VC14RedistX64 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[1E6C:2F30][2022-05-24T22:14:10]i000: VC14RedistX64 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[1E6C:2F30][2022-05-24T22:14:10]i000: VC14RedistX86 AnalyzeFeatureConditions: LaunchAction=Install[1E6C:2F30][2022-05-24T22:14:10]i000: VC14RedistX86 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[1E6C:2F30][2022-05-24T22:14:10]i000: VC14RedistX86 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[1E6C:2F30][2022-05-24T22:14:10]i000: BentleyConnectClient AnalyzeFeatureConditions: LaunchAction=Install[1E6C:2F30][2022-05-24T22:14:10]i000: BentleyConnectClient AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[1E6C:2F30][2022-05-24T22:14:10]i000: BentleyConnectClient AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[1E6C:2F30][2022-05-24T22:14:10]i000: iTwinServicesAddIn AnalyzeFeatureConditions: LaunchAction=Install[1E6C:2F30][2022-05-24T22:14:10]i000: iTwinServicesAddIn AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[1E6C:2F30][2022-05-24T22:14:10]i000: iTwinServicesAddIn AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[1E6C:2F30][2022-05-24T22:14:10]i000: SqlCE35SP2_x86 AnalyzeFeatureConditions: LaunchAction=Install[1E6C:2F30][2022-05-24T22:14:10]i000: SqlCE35SP2_x86 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[1E6C:2F30][2022-05-24T22:14:10]i000: SqlCE35SP2_x86 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[1E6C:2F30][2022-05-24T22:14:10]i000: SqlCE35SP2_x64 AnalyzeFeatureConditions: LaunchAction=Install[1E6C:2F30][2022-05-24T22:14:10]i000: SqlCE35SP2_x64 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[1E6C:2F30][2022-05-24T22:14:10]i000: SqlCE35SP2_x64 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[1E6C:2F30][2022-05-24T22:14:10]i000: SpcCatalog AnalyzeFeatureConditions: LaunchAction=Install[1E6C:2F30][2022-05-24T22:14:10]i000: SpcCatalog AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[1E6C:2F30][2022-05-24T22:14:10]i000: SpcCatalog AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[1E6C:2F30][2022-05-24T22:14:10]i000: SpcServer AnalyzeFeatureConditions: LaunchAction=Install[1E6C:2F30][2022-05-24T22:14:10]i000: SpcServer AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[1E6C:2F30][2022-05-24T22:14:10]i000: SpcServer AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[1E6C:2F30][2022-05-24T22:14:10]i000: StaadProPackage AnalyzeFeatureConditions: LaunchAction=Install[1E6C:2F30][2022-05-24T22:14:10]i000: StaadProPackage AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[1E6C:2F30][2022-05-24T22:14:10]i000: StaadProPackage AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[1E6C:2F30][2022-05-24T22:14:10]i000: StaadProPackage_StaadProShortcuts AnalyzeFeatureConditions: LaunchAction=Install[1E6C:2F30][2022-05-24T22:14:10]i000: StaadProPackage_StaadProShortcuts AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[1E6C:2F30][2022-05-24T22:14:10]i000: StaadProPackage_StaadProShortcuts AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[1E6C:2F30][2022-05-24T22:14:10]i000: StaadProPackage_StaadProDesktopShortcut AnalyzeFeatureConditions: LaunchAction=Install[1E6C:2F30][2022-05-24T22:14:10]i000: StaadProPackage_StaadProDesktopShortcut AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[1E6C:2F30][2022-05-24T22:14:10]i000: StaadProPackage_StaadProDesktopShortcut AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[1E6C:2F30][2022-05-24T22:14:10]i000: StaadProPackage_StaadProStartMenuShortcut AnalyzeFeatureConditions: LaunchAction=Install[1E6C:2F30][2022-05-24T22:14:10]i000: StaadProPackage_StaadProStartMenuShortcut AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[1E6C:2F30][2022-05-24T22:14:10]i000: StaadProPackage_StaadProStartMenuShortcut AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[1E6C:2F30][2022-05-24T22:14:10]i000: StaadProPackage_StaadProSampleModels AnalyzeFeatureConditions: LaunchAction=Install[1E6C:2F30][2022-05-24T22:14:10]i000: StaadProPackage_StaadProSampleModels AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[1E6C:2F30][2022-05-24T22:14:10]i000: StaadProPackage_StaadProSampleModels AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[1E6C:2F30][2022-05-24T22:14:10]i000: RCDC AnalyzeFeatureConditions: LaunchAction=Install[1E6C:2F30][2022-05-24T22:14:10]i000: RCDC AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[1E6C:2F30][2022-05-24T22:14:10]i000: RCDC AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[1E6C:2F30][2022-05-24T22:14:10]i000: BuildingPlanner AnalyzeFeatureConditions: LaunchAction=Install[1E6C:2F30][2022-05-24T22:14:10]i000: BuildingPlanner AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[1E6C:2F30][2022-05-24T22:14:10]i000: BuildingPlanner AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[1E6C:2F30][2022-05-24T22:14:10]i000: VC10RedistX86 AnalyzeFeatureConditions: LaunchAction=Install[1E6C:2F30][2022-05-24T22:14:10]i000: VC10RedistX86 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[1E6C:2F30][2022-05-24T22:14:10]i000: VC10RedistX86 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[1E6C:2F30][2022-05-24T22:14:10]i000: StructuralSynchronizer AnalyzeFeatureConditions: LaunchAction=Install[1E6C:2F30][2022-05-24T22:14:10]i000: StructuralSynchronizer AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[1E6C:2F30][2022-05-24T22:14:10]i000: StructuralSynchronizer AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True[1E6C:2F30][2022-05-24T22:14:10]i000: STAADFoundationAdvanced_x86 AnalyzeFeatureConditions: LaunchAction=Install[1E6C:2F30][2022-05-24T22:14:10]i000: STAADFoundationAdvanced_x86 AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[1E6C:2F30][2022-05-24T22:14:10]i000: STAADFoundationAdvanced_x86 AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False[1E6C:2F30][2022-05-24T22:14:10]i000: Detection complete planned action: Install[1E6C:2F30][2022-05-24T22:14:10]i000: DetectComplete (): Since action is =Install, performing CheckForAddOnRelatedBundle[1E6C:2F30][2022-05-24T22:14:10]i000: CheckForAddOnRelatedBundle (): CURRENT Bundle Tag properties IsAddOn=False, IsLangPack=False, IsPatch=False, IsWin64=True, Classification=, ServicePack=0[1E6C:2F30][2022-05-24T22:14:10]e000: CheckForAddOnRelatedBundle (): This product is not a Patch, LangPack or AddOn. Hence, not searching for related bundles[1E6C:2F30][2022-05-24T22:14:10]i052: Condition 'Privileged OR BePlannedAction~="Layout" OR SkipPrivilegeCheck' evaluates to true.[1E6C:2F30][2022-05-24T22:14:10]i052: Condition 'STAADPro_QAnR_Build_Install_State <> 5' evaluates to true.[1E6C:2F30][2022-05-24T22:14:10]i000: WixInstallBA::SilentPlan[1E6C:2F30][2022-05-24T22:14:10]i000: [1E6C:2F30][2022-05-24T22:14:10]i000: Checking ADDLOCAL and REMOVE...[1E6C:2F30][2022-05-24T22:14:10]i199: Detect complete, result: 0x0[1E6C:3200][2022-05-24T22:14:28]i052: Condition 'NOT BePlannedAction="Uninstall" AND NOT BePlannedAction="Repair"' evaluates to true.[1E6C:3200][2022-05-24T22:14:44]i000: WixInstallBA::Plan[1E6C:3200][2022-05-24T22:14:44]i000: WixInstallBA::SetupModel Plan[1E6C:3200][2022-05-24T22:14:44]i000: SetupModel::Before Plan[1E6C:325C][2022-05-24T22:14:44]i000: Before Plan Async[1E6C:325C][2022-05-24T22:14:44]i000: SetupViewModel::Before Plan[1E6C:325C][2022-05-24T22:14:44]i000: FeatureNodeMachineState.Present True[1E6C:325C][2022-05-24T22:14:44]i000: IsAnythingToDownload: Demanded by VC14RedistX64[1E6C:325C][2022-05-24T22:14:44]i000: WixInstallBA::Before Plan Complete[1E6C:325C][2022-05-24T22:14:44]i000: WixInstallBA::Engine Plan[1E6C:2F30][2022-05-24T22:14:44]i200: Plan begin, 15 packages, action: Install[1E6C:2F30][2022-05-24T22:14:44]w321: Skipping dependency registration on package with no dependency providers: DotNet472Full[1E6C:2F30][2022-05-24T22:14:44]w321: Skipping dependency registration on package with no dependency providers: VC14RedistX64[1E6C:2F30][2022-05-24T22:14:44]i000: Setting string variable 'WixBundleLog_VC14RedistX64' to value 'C:\Users\user\AppData\Local\Temp\STAAD.Pro_CONNECT_Edition_V22_Update_9_20220524221350_000_VC14RedistX64.log'[1E6C:2F30][2022-05-24T22:14:44]w321: Skipping dependency registration on package with no dependency providers: VC14RedistX86[1E6C:2F30][2022-05-24T22:14:44]i000: Setting string variable 'WixBundleLog_VC14RedistX86' to value 'C:\Users\user\AppData\Local\Temp\STAAD.Pro_CONNECT_Edition_V22_Update_9_20220524221350_001_VC14RedistX86.log'[1E6C:2F30][2022-05-24T22:14:44]w321: Skipping dependency registration on package with no dependency providers: BentleyConnectClient[1E6C:2F30][2022-05-24T22:14:44]i000: Setting string variable 'WixBundleLog_BentleyConnectClient' to value 'C:\Users\user\AppData\Local\Temp\STAAD.Pro_CONNECT_Edition_V22_Update_9_20220524221350_002_BentleyConnectClient.log'[1E6C:2F30][2022-05-24T22:14:44]w321: Skipping dependency registration on package with no dependency providers: iTwinServicesAddIn[1E6C:2F30][2022-05-24T22:14:44]i000: Setting string variable 'WixBundleLog_iTwinServicesAddIn' to value 'C:\Users\user\AppData\Local\Temp\STAAD.Pro_CONNECT_Edition_V22_Update_9_20220524221350_003_iTwinServicesAddIn.log'[1E6C:2F30][2022-05-24T22:14:44]i052: Condition 'NOT SqlCE35SP2_x86InstalledVersion >= v3.5.8080.0' evaluates to true.[1E6C:2F30][2022-05-24T22:14:44]i000: Setting string variable 'WixBundleLog_SqlCE35SP2_x86' to value 'C:\Users\user\AppData\Local\Temp\STAAD.Pro_CONNECT_Edition_V22_Update_9_20220524221350_004_SqlCE35SP2_x86.log'[1E6C:2F30][2022-05-24T22:14:44]i052: Condition 'NOT SqlCE35SP2_x64InstalledVersion >= v3.5.8080.0' evaluates to true.[1E6C:2F30][2022-05-24T22:14:44]i000: Setting string variable 'WixBundleLog_SqlCE35SP2_x64' to value 'C:\Users\user\AppData\Local\Temp\STAAD.Pro_CONNECT_Edition_V22_Update_9_20220524221350_005_SqlCE35SP2_x64.log'[1E6C:2F30][2022-05-24T22:14:44]i000: Setting string variable 'WixBundleLog_SpcCatalog' to value 'C:\Users\user\AppData\Local\Temp\STAAD.Pro_CONNECT_Edition_V22_Update_9_20220524221350_006_SpcCatalog.log'[1E6C:2F30][2022-05-24T22:14:44]i000: Setting string variable 'WixBundleLog_SpcServer' to value 'C:\Users\user\AppData\Local\Temp\STAAD.Pro_CONNECT_Edition_V22_Update_9_20220524221350_007_SpcServer.log'[1E6C:2F30][2022-05-24T22:14:44]i204: Plan 5 msi features for package: StaadProPackage[1E6C:2F30][2022-05-24T22:14:44]i000: Setting string variable 'StaadProPackage_DefaultFeature_IsInstalling' to value '1'[1E6C:2F30][2022-05-24T22:14:44]i203: Planned feature: DefaultFeature, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove[1E6C:2F30][2022-05-24T22:14:44]i000: Setting string variable 'StaadProPackage_StaadProDesktopShortcut_IsInstalling' to value '1'[1E6C:2F30][2022-05-24T22:14:44]i203: Planned feature: StaadProDesktopShortcut, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove[1E6C:2F30][2022-05-24T22:14:44]i000: Setting string variable 'StaadProPackage_StaadProShortcuts_IsInstalling' to value '1'[1E6C:2F30][2022-05-24T22:14:44]i203: Planned feature: StaadProShortcuts, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove[1E6C:2F30][2022-05-24T22:14:44]i000: Setting string variable 'StaadProPackage_StaadProStartMenuShortcut_IsInstalling' to value '1'[1E6C:2F30][2022-05-24T22:14:44]i203: Planned feature: StaadProStartMenuShortcut, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove[1E6C:2F30][2022-05-24T22:14:44]i000: Setting string variable 'StaadProPackage_StaadProSampleModels_IsInstalling' to value '1'[1E6C:2F30][2022-05-24T22:14:44]i203: Planned feature: StaadProSampleModels, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove[1E6C:2F30][2022-05-24T22:14:44]i000: Setting string variable 'WixBundleRollbackLog_StaadProPackage' to value 'C:\Users\user\AppData\Local\Temp\STAAD.Pro_CONNECT_Edition_V22_Update_9_20220524221350_008_StaadProPackage_rollback.log'[1E6C:2F30][2022-05-24T22:14:44]i000: Setting string variable 'WixBundleLog_StaadProPackage' to value 'C:\Users\user\AppData\Local\Temp\STAAD.Pro_CONNECT_Edition_V22_Update_9_20220524221350_008_StaadProPackage.log'[1E6C:2F30][2022-05-24T22:14:44]w321: Skipping dependency registration on package with no dependency providers: RCDC[1E6C:2F30][2022-05-24T22:14:44]i000: Setting string variable 'WixBundleLog_RCDC' to value 'C:\Users\user\AppData\Local\Temp\STAAD.Pro_CONNECT_Edition_V22_Update_9_20220524221350_009_RCDC.log'[1E6C:2F30][2022-05-24T22:14:44]w321: Skipping dependency registration on package with no dependency providers: VC10RedistX86[1E6C:2F30][2022-05-24T22:14:44]i000: Setting string variable 'WixBundleLog_VC10RedistX86' to value 'C:\Users\user\AppData\Local\Temp\STAAD.Pro_CONNECT_Edition_V22_Update_9_20220524221350_010_VC10RedistX86.log'[1E6C:2F30][2022-05-24T22:14:44]i000: Setting string variable 'WixBundleLog_BuildingPlanner' to value 'C:\Users\user\AppData\Local\Temp\STAAD.Pro_CONNECT_Edition_V22_Update_9_20220524221350_011_BuildingPlanner.log'[1E6C:2F30][2022-05-24T22:14:44]w321: Skipping dependency registration on package with no dependency providers: StructuralSynchronizer[1E6C:2F30][2022-05-24T22:14:44]i000: Setting string variable 'WixBundleLog_StructuralSynchronizer' to value 'C:\Users\user\AppData\Local\Temp\STAAD.Pro_CONNECT_Edition_V22_Update_9_20220524221350_012_StructuralSynchronizer.log'[1E6C:2F30][2022-05-24T22:14:44]w321: Skipping dependency registration on package with no dependency providers: STAADFoundationAdvanced_x86[1E6C:2F30][2022-05-24T22:14:44]i000: Setting string variable 'WixBundleLog_STAADFoundationAdvanced_x86' to value 'C:\Users\user\AppData\Local\Temp\STAAD.Pro_CONNECT_Edition_V22_Update_9_20220524221350_013_STAADFoundationAdvanced_x86.log'[1E6C:2F30][2022-05-24T22:14:44]i201: Planned package: DotNet472Full, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None[1E6C:2F30][2022-05-24T22:14:44]i201: Planned package: VC14RedistX64, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: No, uncache: Yes, dependency: None[1E6C:2F30][2022-05-24T22:14:44]i201: Planned package: VC14RedistX86, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: No, uncache: Yes, dependency: None[1E6C:2F30][2022-05-24T22:14:44]i201: Planned package: BentleyConnectClient, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: No, uncache: No, dependency: None[1E6C:2F30][2022-05-24T22:14:44]i201: Planned package: iTwinServicesAddIn, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: No, uncache: No, dependency: None[1E6C:2F30][2022-05-24T22:14:44]i201: Planned package: SqlCE35SP2_x86, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: No, uncache: No, dependency: Register[1E6C:2F30][2022-05-24T22:14:44]i201: Planned package: SqlCE35SP2_x64, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: No, uncache: No, dependency: Register[1E6C:2F30][2022-05-24T22:14:44]i201: Planned package: SpcCatalog, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: No, uncache: No, dependency: Register[1E6C:2F30][2022-05-24T22:14:44]i201: Planned package: SpcServer, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: No, uncache: No, dependency: Register[1E6C:2F30][2022-05-24T22:14:44]i201: Planned package: StaadProPackage, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register[1E6C:2F30][2022-05-24T22:14:44]i201: Planned package: RCDC, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: Yes, uncache: No, dependency: None[1E6C:2F30][2022-05-24T22:14:44]i201: Planned package: VC10RedistX86, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: Yes, uncache: Yes, dependency: None[1E6C:2F30][2022-05-24T22:14:44]i201: Planned package: BuildingPlanner, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: Yes, uncache: No, dependency: Register[1E6C:2F30][2022-05-24T22:14:44]i201: Planned package: StructuralSynchronizer, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: Yes, uncache: No, dependency: None[1E6C:2F30][2022-05-24T22:14:44]i201: Planned package: STAADFoundationAdvanced_x86, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: Yes, uncache: No, dependency: None[1E6C:2F30][2022-05-24T22:14:44]i000: GetWindowsRootDriveName (): winRoot=C:\[1E6C:2F30][2022-05-24T22:14:44]i000: IsPathRooted (C:\): true[1E6C:2F30][2022-05-24T22:14:44]i000: GetWindowsRootDriveName (): DriveInfo.Name=C:\[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): windowsRootDrive=C:\[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): windowsRootDrive=C:\, FileInfo.Length=3716120, FileName=C:\Users\user\Downloads\Setup_StaadProx64_22.09.00.115.exe[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Feature already installed = Microsoft .NET Framework 4.7.2. Next[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=3716120[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=14887048, NewSize=18603168[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=18603168[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=14337656, NewSize=32940824[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=32940824[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=228691752, NewSize=261632576[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=261632576[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=181601952, NewSize=443234528[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=443234528[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=9758503, NewSize=452993031[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=452993031[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=10403456, NewSize=463396487[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=463396487[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=40199526, NewSize=503596013[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=503596013[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=81548396, NewSize=585144409[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=585144409[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=1978840117, NewSize=2563984526[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Feature is not a package = Shortcuts. Next[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Feature is not a package = Desktop Shortcuts. Next[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Feature is not a package = Start Menu Shortcuts. Next[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Feature is not a package = Sample and Verification Models. Next[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=2563984526[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=796418568, NewSize=3360403094[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=3360403094[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=44318227, NewSize=3404721321[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=3404721321[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=4995416, NewSize=3409716737[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=3409716737[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=2203344, NewSize=3411920081[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Drive=C:\, DownloadSize=3411920081[1E6C:2F30][2022-05-24T22:14:44]i000: getUsedDriveNamesForInstall (): Appending DriveName=C:\, Size=581020032, NewSize=3992940113[1E6C:2F30][2022-05-24T22:14:45]i000: checkInstallSize (): Checking for drive C:\[1E6C:2F30][2022-05-24T22:14:45]i000: checkInstallSize (): Requested Drive-List contains drive C:\[1E6C:2F30][2022-05-24T22:14:45]i000: checkInstallSize (): Checking for drive D:\[1E6C:2F30][2022-05-24T22:14:45]i000: validateInstallSize (): Result=True[1E6C:2F30][2022-05-24T22:14:45]i000: PlanComplete: Called[1E6C:2F30][2022-05-24T22:14:45]i000: Setting string variable 'DotNet472Full_RequestedState' to value '1'[1E6C:2F30][2022-05-24T22:14:45]i000: Setting string variable 'VC14RedistX64_RequestedState' to value '1'[1E6C:2F30][2022-05-24T22:14:45]i000: Setting string variable 'VC14RedistX86_RequestedState' to value '1'[1E6C:2F30][2022-05-24T22:14:45]i000: Setting string variable 'BentleyConnectClient_RequestedState' to value '1'[1E6C:2F30][2022-05-24T22:14:45]i000: Setting string variable 'iTwinServicesAddIn_RequestedState' to value '1'[1E6C:2F30][2022-05-24T22:14:45]i000: Setting string variable 'SqlCE35SP2_x86_RequestedState' to value '1'[1E6C:2F30][2022-05-24T22:14:45]i000: Setting string variable 'SqlCE35SP2_x64_RequestedState' to value '1'[1E6C:2F30][2022-05-24T22:14:45]i000: Setting string variable 'SpcCatalog_RequestedState' to value '1'[1E6C:2F30][2022-05-24T22:14:45]i000: Setting string variable 'SpcServer_RequestedState' to value '1'[1E6C:2F30][2022-05-24T22:14:45]i000: Setting string variable 'StaadProPackage_RequestedState' to value '1'[1E6C:2F30][2022-05-24T22:14:45]i000: Setting string variable 'StaadProPackage_StaadProShortcuts_RequestedState' to value '1'[1E6C:2F30][2022-05-24T22:14:45]i000: Setting string variable 'StaadProPackage_StaadProDesktopShortcut_RequestedState' to value '1'[1E6C:2F30][2022-05-24T22:14:45]i000: Setting string variable 'StaadProPackage_StaadProStartMenuShortcut_RequestedState' to value '1'[1E6C:2F30][2022-05-24T22:14:45]i000: Setting string variable 'StaadProPackage_StaadProSampleModels_RequestedState' to value '1'[1E6C:2F30][2022-05-24T22:14:45]i000: Setting string variable 'RCDC_RequestedState' to value '1'[1E6C:2F30][2022-05-24T22:14:45]i000: Setting string variable 'BuildingPlanner_RequestedState' to value '1'[1E6C:2F30][2022-05-24T22:14:45]i000: Setting string variable 'VC10RedistX86_RequestedState' to value '1'[1E6C:2F30][2022-05-24T22:14:45]i000: Setting string variable 'StructuralSynchronizer_RequestedState' to value '1'[1E6C:2F30][2022-05-24T22:14:45]i000: Setting string variable 'STAADFoundationAdvanced_x86_RequestedState' to value '1'[1E6C:2F30][2022-05-24T22:14:45]i000: WixInstallBA::Apply[1E6C:2F30][2022-05-24T22:14:45]i000: WixInstallBA::Engine Apply[1E6C:2F30][2022-05-24T22:14:45]i299: Plan complete, result: 0x0[1E6C:2F30][2022-05-24T22:14:45]i300: Apply begin[1E6C:3200][2022-05-24T22:14:45]i000: ErrorPage Code: 0[1E6C:2F30][2022-05-24T22:14:45]i010: Launching elevated engine process.[1E6C:2F30][2022-05-24T22:14:51]i011: Launched elevated engine process.[1E6C:2F30][2022-05-24T22:14:51]i012: Connected to elevated engine.[0818:1BD4][2022-05-24T22:14:51]i358: Pausing automatic updates.[0818:1BD4][2022-05-24T22:14:51]i359: Paused automatic updates.[0818:1BD4][2022-05-24T22:14:51]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{f1536c0f-09fc-4a78-8e53-d80eb35d792e}, options: 0x7, disable resume: No[0818:1BD4][2022-05-24T22:14:51]i000: Caching bundle from: 'C:\Users\user\AppData\Local\Temp\{0BD0DD40-C15E-42AF-B6BA-9A4E99F374DE}\.be\Setup_StaadProx64_22.09.00.115.exe' to: 'C:\ProgramData\Package Cache\{f1536c0f-09fc-4a78-8e53-d80eb35d792e}\Setup_StaadProx64_22.09.00.115.exe'[0818:1BD4][2022-05-24T22:14:51]i320: Registering bundle dependency provider: {f1536c0f-09fc-4a78-8e53-d80eb35d792e}, version: 22.9.0.115[0818:1BD4][2022-05-24T22:14:51]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{f1536c0f-09fc-4a78-8e53-d80eb35d792e}, resume: Active, restart initiated: No, disable resume: No[1E6C:2F30][2022-05-24T22:14:51]i000: Installation chain initiated package from [0818:1E84][2022-05-24T22:14:51]i304: Verified existing payload: VC14RedistX64 at path: C:\ProgramData\Package Cache\1786EE165231D491F209FD27B6E3029556AF25BC\vc_redist.x64.exe.[1E6C:2F30][2022-05-24T22:14:51]i000: Installing VC14RedistX64[1E6C:2F30][2022-05-24T22:14:51]i000: Setting string variable 'ProductsInstalledByBundle' to value 'NoProductList;vc14redistx64'[0818:1BD4][2022-05-24T22:14:51]i301: Applying execute package: VC14RedistX64, action: Install, path: C:\ProgramData\Package Cache\1786EE165231D491F209FD27B6E3029556AF25BC\vc_redist.x64.exe, arguments: '"C:\ProgramData\Package Cache\1786EE165231D491F209FD27B6E3029556AF25BC\vc_redist.x64.exe" /install /quiet /norestart'[0818:1E84][2022-05-24T22:14:51]i304: Verified existing payload: VC14RedistX86 at path: C:\ProgramData\Package Cache\85354326EF8FBE908D9331446B8C8463577C5633\vc_redist.x86.exe.[0818:1E84][2022-05-24T22:14:53]i304: Verified existing payload: BentleyConnectClient at path: C:\ProgramData\Package Cache\5DE83B201CF9CF9180D3C833F56D45FD18BB242E\Setup_CONNECTIONClientx64_11.00.04.15.exe.[0818:1E84][2022-05-24T22:14:55]i304: Verified existing payload: iTwinServicesAddIn at path: C:\ProgramData\Package Cache\5C6ED665BD32B23F2F21AD7EECAFD77909E4310F\Setup_iTwinServicesAddInV2x64_02.00.00.111.exe.[0818:1E84][2022-05-24T22:14:55]i304: Verified existing payload: SqlCE35SP2_x86 at path: C:\ProgramData\Package Cache\{3A9FC03D-C685-4831-94CF-4EDFD3749497}v3.5.8080.0\SSCERuntime_x86-ENU.msi.[0818:1E84][2022-05-24T22:14:55]i304: Verified existing payload: SqlCE35SP2_x64 at path: C:\ProgramData\Package Cache\{D4AD39AD-091E-4D33-BB2B-59F6FCB8ADC3}v3.5.8080.0\SSCERuntime_x64-ENU.msi.[0818:1E84][2022-05-24T22:14:55]i304: Verified existing payload: SpcCatalog at path: C:\ProgramData\Package Cache\{D6F32D32-986F-4A51-8992-B83F18009F32}v3.1.4.5\SPCSetup.3.1.4.5.msi.[0818:1E84][2022-05-24T22:14:55]i304: Verified existing payload: SpcServer at path: C:\ProgramData\Package Cache\{95A29BC0-7475-3BBA-8977-4F1BBBDB5A49}v10.00.00.015\SPCx64.msi.[1E6C:2F30][2022-05-24T22:14:56]i000: Installed package VC14RedistX64[1E6C:2F30][2022-05-24T22:14:56]i319: Applied execute package: VC14RedistX64, result: 0x0, restart: None[1E6C:2F30][2022-05-24T22:14:56]i000: Installing VC14RedistX86[1E6C:2F30][2022-05-24T22:14:56]i000: Setting string variable 'ProductsInstalledByBundle' to value 'NoProductList;vc14redistx64;vc14redistx86'[0818:1BD4][2022-05-24T22:14:56]i301: Applying execute package: VC14RedistX86, action: Install, path: C:\ProgramData\Package Cache\85354326EF8FBE908D9331446B8C8463577C5633\vc_redist.x86.exe, arguments: '"C:\ProgramData\Package Cache\85354326EF8FBE908D9331446B8C8463577C5633\vc_redist.x86.exe" /install /quiet /norestart'[0818:1E84][2022-05-24T22:14:59]i304: Verified existing payload: StaadProPackage at path: C:\ProgramData\Package Cache\{039C2AC9-6623-39FB-B8CC-1438F1419951}v22.09.00.115\StaadProx64.msi.[1E6C:1230][2022-05-24T22:14:59]w343: Prompt for source of package: RCDC, payload: RCDC, path: C:\Users\user\Downloads\Setup_RCDCx64_11.02.00.200.exe[1E6C:1230][2022-05-24T22:14:59]i000: ResolveSource: Retries value 1[1E6C:1230][2022-05-24T22:14:59]i000: ResolveSource: Checking with PayloadService package RCDC[1E6C:1230][2022-05-24T22:14:59]e000: WaitForProxyAuthentication: Waiting for proxy authentication[1E6C:1230][2022-05-24T22:14:59]i000: Opening the mapping file at C:\Users\user\AppData\Local\Temp\{0BD0DD40-C15E-42AF-B6BA-9A4E99F374DE}\.ba\extRes.bin[1E6C:1230][2022-05-24T22:14:59]i000: Parsing ExtPayloadId for DotNet472Full=31fc0d30-5a6f-551c-9e89-2c98eb10997a[1E6C:1230][2022-05-24T22:14:59]i000: Parsing ExtPayloadId for VC14RedistX64=1786ee16-5231-5491-b209-fd27b6e30295[1E6C:1230][2022-05-24T22:14:59]i000: Parsing ExtPayloadId for VC14RedistX86=85354326-ef8f-5e90-8d93-31446b8c8463[1E6C:1230][2022-05-24T22:14:59]i000: Parsing ExtPayloadId for BentleyConnectClient=540ee2af-d8c0-4c03-abce-8772963b5f7b[1E6C:1230][2022-05-24T22:14:59]i000: Parsing ExtPayloadId for iTwinServicesAddIn=1e09f815-0c73-43cb-a233-761f0fd03d89[1E6C:1230][2022-05-24T22:14:59]i000: Parsing ExtPayloadId for SqlCE35SP2_x86=84395861-2117-43ce-9029-6d1a73f6929a[1E6C:1230][2022-05-24T22:14:59]i000: Parsing ExtPayloadId for SqlCE35SP2_x64=a8561516-5654-439f-a50c-2e84b389c11d[1E6C:1230][2022-05-24T22:14:59]i000: Parsing ExtPayloadId for SpcCatalog=03aca56a-bc74-4bb2-8113-8a4416cee37d[1E6C:1230][2022-05-24T22:14:59]i000: Parsing ExtPayloadId for SpcServer=840fd0c0-a628-45e5-a249-0cee27e86839[1E6C:1230][2022-05-24T22:14:59]i000: Parsing ExtPayloadId for StaadProPackage=381f87f0-954d-4535-8bc7-5fc1b044c603[1E6C:1230][2022-05-24T22:14:59]i000: Parsing ExtPayloadId for RCDC=539a6f1b-de8d-49da-aaff-d31b50c163e9[1E6C:1230][2022-05-24T22:14:59]i000: Parsing ExtPayloadId for VC10RedistX86=b84b83a8-a674-5a17-bfb5-f3578b983c1d[1E6C:1230][2022-05-24T22:14:59]i000: Parsing ExtPayloadId for BuildingPlanner=e2a20f56-c232-4c9b-b3c3-663e082605a2[1E6C:1230][2022-05-24T22:14:59]i000: Parsing ExtPayloadId for StructuralSynchronizer=3425c5fc-14ff-40e5-9748-24e0264a1383[1E6C:1230][2022-05-24T22:14:59]i000: Parsing ExtPayloadId for STAADFoundationAdvanced_x86=ebcc66cb-b57c-4f34-97b1-f7bb3d4161ff[1E6C:1230][2022-05-24T22:14:59]i000: UserDomainName: DESKTOP-64OHFM6[1E6C:1230][2022-05-24T22:14:59]i000: Fetch Download URL for PayloadId = 539a6f1b-de8d-49da-aaff-d31b50c163e9, Resolver = , RetryCount = 0[1E6C:1230][2022-05-24T22:14:59]e000: SetHeaders (): Added bootstrapper id in header, {f1536c0f-09fc-4a78-8e53-d80eb35d792e}[1E6C:1230][2022-05-24T22:14:59]i000: Getting resolver URL. Attempt: 1[1E6C:1230][2022-05-24T22:14:59]i000: Resolving from URL: payloadresolvesvc.bentley.com/.../[1E6C:1230][2022-05-24T22:14:59]i000: Resolving from URL: payloadresolvesvc.bentley.com/.../[1E6C:1230][2022-05-24T22:15:00]i000: Payload DownloadString = {"Status":0,"PayloadPath":""ErrorMessage":null}">cdnllnw.bentley.com/.../setup_rcdcx64_11.02.00.200.exe[1E6C:1230][2022-05-24T22:15:00]i000: Payload Response.PayloadPath = cdnllnw.bentley.com/.../setup_rcdcx64_11.02.00.200.exe[1E6C:1230][2022-05-24T22:15:00]e000: RCDC is an OnDemand Package, downloaded path is cdnllnw.bentley.com/.../setup_rcdcx64_11.02.00.200.exe[1E6C:1230][2022-05-24T22:15:00]i338: Acquiring package: RCDC, payload: RCDC, download from: cdnllnw.bentley.com/.../setup_rcdcx64_11.02.00.200.exe[1E6C:2F30][2022-05-24T22:15:00]i000: Installed package VC14RedistX86[1E6C:2F30][2022-05-24T22:15:00]i319: Applied execute package: VC14RedistX86, result: 0x0, restart: None[1E6C:2F30][2022-05-24T22:15:00]i000: Installing BentleyConnectClient[1E6C:2F30][2022-05-24T22:15:00]i000: Setting string variable 'ProductsInstalledByBundle' to value 'NoProductList;vc14redistx64;vc14redistx86;bentleyconnectclient'[0818:1BD4][2022-05-24T22:15:00]i301: Applying execute package: BentleyConnectClient, action: Install, path: C:\ProgramData\Package Cache\5DE83B201CF9CF9180D3C833F56D45FD18BB242E\Setup_CONNECTIONClientx64_11.00.04.15.exe, arguments: '"C:\ProgramData\Package Cache\5DE83B201CF9CF9180D3C833F56D45FD18BB242E\Setup_CONNECTIONClientx64_11.00.04.15.exe" /install /quiet -burn.filehandle.self=940'[1E6C:2F30][2022-05-24T22:16:37]i000: Installed package BentleyConnectClient[1E6C:2F30][2022-05-24T22:16:37]i319: Applied execute package: BentleyConnectClient, result: 0x0, restart: None[1E6C:2F30][2022-05-24T22:16:37]i000: Installing iTwinServicesAddIn[1E6C:2F30][2022-05-24T22:16:37]i000: Setting string variable 'ProductsInstalledByBundle' to value 'NoProductList;vc14redistx64;vc14redistx86;bentleyconnectclient;itwinservicesaddin'[0818:1BD4][2022-05-24T22:16:37]i301: Applying execute package: iTwinServicesAddIn, action: Install, path: C:\ProgramData\Package Cache\5C6ED665BD32B23F2F21AD7EECAFD77909E4310F\Setup_iTwinServicesAddInV2x64_02.00.00.111.exe, arguments: '"C:\ProgramData\Package Cache\5C6ED665BD32B23F2F21AD7EECAFD77909E4310F\Setup_iTwinServicesAddInV2x64_02.00.00.111.exe" /install /quiet -burn.filehandle.self=1012'[1E6C:2F30][2022-05-24T22:17:25]i000: Installed package iTwinServicesAddIn[1E6C:2F30][2022-05-24T22:17:25]i319: Applied execute package: iTwinServicesAddIn, result: 0x0, restart: None[0818:1BD4][2022-05-24T22:17:25]i323: Registering package dependency provider: {3A9FC03D-C685-4831-94CF-4EDFD3749497}, version: 3.5.8080.0, package: SqlCE35SP2_x86[1E6C:2F30][2022-05-24T22:17:25]i000: Installing SqlCE35SP2_x86[1E6C:2F30][2022-05-24T22:17:25]i000: Setting string variable 'ProductsInstalledByBundle' to value 'NoProductList;vc14redistx64;vc14redistx86;bentleyconnectclient;itwinservicesaddin;sqlce35sp2_x86'[0818:1BD4][2022-05-24T22:17:25]i301: Applying execute package: SqlCE35SP2_x86, action: Install, path: C:\ProgramData\Package Cache\{3A9FC03D-C685-4831-94CF-4EDFD3749497}v3.5.8080.0\SSCERuntime_x86-ENU.msi, arguments: ' ALLUSERS="1" MSIFASTINSTALL="7"'[1E6C:2F30][2022-05-24T22:17:30]i000: Installed package SqlCE35SP2_x86[1E6C:2F30][2022-05-24T22:17:30]i319: Applied execute package: SqlCE35SP2_x86, result: 0x0, restart: None[0818:1BD4][2022-05-24T22:17:30]i325: Registering dependency: {f1536c0f-09fc-4a78-8e53-d80eb35d792e} on package provider: {3A9FC03D-C685-4831-94CF-4EDFD3749497}, package: SqlCE35SP2_x86[0818:1BD4][2022-05-24T22:17:30]i323: Registering package dependency provider: {D4AD39AD-091E-4D33-BB2B-59F6FCB8ADC3}, version: 3.5.8080.0, package: SqlCE35SP2_x64[1E6C:2F30][2022-05-24T22:17:30]i000: Installing SqlCE35SP2_x64[1E6C:2F30][2022-05-24T22:17:30]i000: Setting string variable 'ProductsInstalledByBundle' to value 'NoProductList;vc14redistx64;vc14redistx86;bentleyconnectclient;itwinservicesaddin;sqlce35sp2_x86;sqlce35sp2_x64'[0818:1BD4][2022-05-24T22:17:30]i301: Applying execute package: SqlCE35SP2_x64, action: Install, path: C:\ProgramData\Package Cache\{D4AD39AD-091E-4D33-BB2B-59F6FCB8ADC3}v3.5.8080.0\SSCERuntime_x64-ENU.msi, arguments: ' ALLUSERS="1" MSIFASTINSTALL="7"'[1E6C:2F30][2022-05-24T22:17:36]i000: Installed package SqlCE35SP2_x64[1E6C:2F30][2022-05-24T22:17:36]i319: Applied execute package: SqlCE35SP2_x64, result: 0x0, restart: None[0818:1BD4][2022-05-24T22:17:36]i325: Registering dependency: {f1536c0f-09fc-4a78-8e53-d80eb35d792e} on package provider: {D4AD39AD-091E-4D33-BB2B-59F6FCB8ADC3}, package: SqlCE35SP2_x64[0818:1BD4][2022-05-24T22:17:36]i323: Registering package dependency provider: {D6F32D32-986F-4A51-8992-B83F18009F32}, version: 3.1.4.5, package: SpcCatalog[1E6C:2F30][2022-05-24T22:17:36]i000: Installing SpcCatalog[1E6C:2F30][2022-05-24T22:17:36]i000: Setting string variable 'ProductsInstalledByBundle' to value 'NoProductList;vc14redistx64;vc14redistx86;bentleyconnectclient;itwinservicesaddin;sqlce35sp2_x86;sqlce35sp2_x64;spccatalog'[0818:1BD4][2022-05-24T22:17:36]i301: Applying execute package: SpcCatalog, action: Install, path: C:\ProgramData\Package Cache\{D6F32D32-986F-4A51-8992-B83F18009F32}v3.1.4.5\SPCSetup.3.1.4.5.msi, arguments: ' ALLUSERS="1" MSIFASTINSTALL="7"'[1E6C:2F30][2022-05-24T22:18:12]i000: Installed package SpcCatalog[1E6C:2F30][2022-05-24T22:18:12]i319: Applied execute package: SpcCatalog, result: 0x0, restart: None[0818:1BD4][2022-05-24T22:18:12]i325: Registering dependency: {f1536c0f-09fc-4a78-8e53-d80eb35d792e} on package provider: {D6F32D32-986F-4A51-8992-B83F18009F32}, package: SpcCatalog[0818:1BD4][2022-05-24T22:18:12]i323: Registering package dependency provider: {95A29BC0-7475-3BBA-8977-4F1BBBDB5A49}, version: 10.00.00.015, package: SpcServer[1E6C:2F30][2022-05-24T22:18:12]i000: Installing SpcServer[1E6C:2F30][2022-05-24T22:18:12]i000: Setting string variable 'ProductsInstalledByBundle' to value 'NoProductList;vc14redistx64;vc14redistx86;bentleyconnectclient;itwinservicesaddin;sqlce35sp2_x86;sqlce35sp2_x64;spccatalog;spcserver'[0818:1BD4][2022-05-24T22:18:12]i301: Applying execute package: SpcServer, action: Install, path: C:\ProgramData\Package Cache\{95A29BC0-7475-3BBA-8977-4F1BBBDB5A49}v10.00.00.015\SPCx64.msi, arguments: ' ALLUSERS="1" MSIFASTINSTALL="7"'[1E6C:2F30][2022-05-24T22:18:21]i000: Installed package SpcServer[1E6C:2F30][2022-05-24T22:18:21]i319: Applied execute package: SpcServer, result: 0x0, restart: None[0818:1BD4][2022-05-24T22:18:21]i325: Registering dependency: {f1536c0f-09fc-4a78-8e53-d80eb35d792e} on package provider: {95A29BC0-7475-3BBA-8977-4F1BBBDB5A49}, package: SpcServer[0818:1BD4][2022-05-24T22:18:21]i323: Registering package dependency provider: {039C2AC9-6623-39FB-B8CC-1438F1419951}, version: 22.09.00.115, package: StaadProPackage[1E6C:2F30][2022-05-24T22:18:21]i000: Installing StaadProPackage[1E6C:2F30][2022-05-24T22:18:21]i000: Setting string variable 'ProductsInstalledByBundle' to value 'NoProductList;vc14redistx64;vc14redistx86;bentleyconnectclient;itwinservicesaddin;sqlce35sp2_x86;sqlce35sp2_x64;spccatalog;spcserver;staadpropackage'[0818:1BD4][2022-05-24T22:18:21]i301: Applying execute package: StaadProPackage, action: Install, path: C:\ProgramData\Package Cache\{039C2AC9-6623-39FB-B8CC-1438F1419951}v22.09.00.115\StaadProx64.msi, arguments: ' ALLUSERS="1" ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7" FROMLAUNCHSETUP="1" INSTALLDIR="C:\Program Files\Bentley\Engineering\STAAD.Pro CONNECT Edition\" SAMPLESDIR="" BE_BUNDLE_NAME="STAAD.Pro CONNECT Edition V22 Update 9" BE_BUNDLE_VERSION="22.9.0.115" BE_BUNDLE_UILEVEL="" ADDLOCAL="DefaultFeature,StaadProDesktopShortcut,StaadProShortcuts,StaadProStartMenuShortcut,StaadProSampleModels"'[0818:1BD4][2022-05-24T22:25:21]e000: Error 0x80070643: Failed to install MSI package.[0818:1BD4][2022-05-24T22:25:21]e000: Error 0x80070643: Failed to execute MSI package.[1E6C:2F30][2022-05-24T22:25:21]e000: Error 0x80070643: Failed to configure per-machine MSI package.[1E6C:2F30][2022-05-24T22:25:21]i000: Installed package StaadProPackage[1E6C:2F30][2022-05-24T22:25:21]i319: Applied execute package: StaadProPackage, result: 0x80070643, restart: None[1E6C:2F30][2022-05-24T22:25:21]e000: Error 0x80070643: Failed to execute MSI package.[1E6C:2F30][2022-05-24T22:25:21]i000: Installing StaadProPackage[0818:1BD4][2022-05-24T22:25:21]i318: Skipped rollback of package: StaadProPackage, action: Uninstall, already: Absent[1E6C:2F30][2022-05-24T22:25:21]i000: Installed package StaadProPackage[1E6C:2F30][2022-05-24T22:25:21]i319: Applied rollback package: StaadProPackage, result: 0x0, restart: None[0818:1BD4][2022-05-24T22:25:21]i329: Removed package dependency provider: {039C2AC9-6623-39FB-B8CC-1438F1419951}, package: StaadProPackage[1E6C:2F30][2022-05-24T22:25:21]i000: Installation chain finished package from [1E6C:3200][2022-05-24T22:25:21]i000: ErrorPage Code: -2147023293[1E6C:1230][2022-05-24T22:25:22]e000: Error 0x80070642: Failed attempt to download URL: 'cdnllnw.bentley.com/.../setup_rcdcx64_11.02.00.200.exe to: 'C:\Users\user\AppData\Local\Temp\{0BD0DD40-C15E-42AF-B6BA-9A4E99F374DE}\RCDC'[1E6C:1230][2022-05-24T22:25:22]e000: Error 0x80070642: Failed to acquire payload from: 'cdnllnw.bentley.com/.../setup_rcdcx64_11.02.00.200.exe to working path: 'C:\Users\user\AppData\Local\Temp\{0BD0DD40-C15E-42AF-B6BA-9A4E99F374DE}\RCDC'[1E6C:1230][2022-05-24T22:25:22]e313: Failed to acquire payload: RCDC to working path: C:\Users\user\AppData\Local\Temp\{0BD0DD40-C15E-42AF-B6BA-9A4E99F374DE}\RCDC, error: 0x80070642.[1E6C:1230][2022-05-24T22:25:22]e000: Cannot download package RCDC[0818:1BD4][2022-05-24T22:26:23]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{f1536c0f-09fc-4a78-8e53-d80eb35d792e}, resume: None, restart: None, disable resume: No[0818:1BD4][2022-05-24T22:26:23]i330: Removed bundle dependency provider: {f1536c0f-09fc-4a78-8e53-d80eb35d792e}[0818:1BD4][2022-05-24T22:26:23]i352: Removing cached bundle: {f1536c0f-09fc-4a78-8e53-d80eb35d792e}, from path: C:\ProgramData\Package Cache\{f1536c0f-09fc-4a78-8e53-d80eb35d792e}\[0818:1BD4][2022-05-24T22:26:23]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{f1536c0f-09fc-4a78-8e53-d80eb35d792e}, resume: None, restart initiated: No, disable resume: No[1E6C:2F30][2022-05-24T22:26:23]i000: No application is set for launch after installation[1E6C:2F30][2022-05-24T22:26:23]i000: Setting string variable 'ZipPathForAllLogFiles' to value 'C:\Users\user\AppData\Local\Temp\STAAD.Pro_CONNECT_Edition_V22_Update_9_20220524221350.zip'[1E6C:2F30][2022-05-24T22:26:28]i399: Apply complete, result: 0x80070643, restart: None, ba requested restart: No
This is the screenshot of the error.
Thanks And Regards
Vyshak Chandrasekhar
Hello Vyshak,
If you do not have any restriction to STAAD.Pro V22.10.00.153 (higher version) the we would suggest you to install the same from Software Downloads (bentley.com)In both the cases, make sure your Windows OS was updated, there is no pre-existing version of STAAD.Pro and its' related applications, Also ensure that Connection Client (CC) is also being removed.Once above conditions are satisfied, go ahead with Right click on the installer followed by a click on 'run as administrator'.If it fails to install please raise a Service Request at https://apps.bentley.com/srmanager/ProductSupport
