The "actual ratio" button, which list beam utilizations in descending order, is not working. How can I fix this? It works on my colleagues computer, with the same edition (22.08.00.175).
Please try the following steps:
Also, if your account is in SELECT, plan on upgrading to the latest version 22.10.00.153.
Thanks. I have tried this, but unfortunately this didn't work. We have also tried re-installing STAAD.Pro, with different versions as well. Can the issue be outside STAAD.Pro, with another computer setting? I see when I push the button that the table "flashes" slightly. So there is a reaction somehow, only that it does not rearrange the beam utilization from beam number to utilization order...
