I received an error like the one in the image below from SFA. Can somebody explain it to me? Why is it that the software is unable to redistribute the pressures? Is it because that all the corners have negative pressures?
Are you getting this error for an isolated footing design? Could you attach the .sfa file here?
Yes, this is for an isolated footing. Please refer to the job entitled "Delete" in the attached SFA file.
0728.[CE 196] - Isolated.sfa
