Hello Everyone !
I Have Done Analysis For Window Model Using Prismatic General Section.
But While Generating Report , No Property Values i.e. Ixx, Iyy, Izz For Prismatic Section Were Displayed in Utilization Ratio Table.
Please Suggest How to get Properties In Utilization Table.
It seems the section properties are too small to show with the unit you choose. If you can change the unit from m^4 to mm^4, then you will be able to see the values. You can change it in the postprocessing utilization table which in tur will affect the report unit also.
