I dont not understand how to properly mesh my nodes so that there is no connectivity issues. Can someone please help. I am trying to mesh the area using nodes 4-1-13-16.
/cfs-file/__key/communityserver-discussions-components-files/5932/comp-slab-R2-_2D00_-cOPY.STD
You can use parametric model option to generate mesh which will consider the internal node connectivity also. Please refer below link and see the video.
https://communities.bentley.com/products/ram-staad/m/structural_analysis_and_design_gallery/274483
