Error Message: ***ERROR*** UNKNOWN MATERIAL TYPE PROVIDED. I have set all the materials myself with specific properties. No material has missing attributes when I click on select missing attributes. I just can't figure out what it thinks is timber.
Here is the full output file script and a screenshot showing the materials. I would really appreciate any help. I could also send the file itself if that would help. Thanks for you help!! Slight smile
* STAAD.Pro V8i SELECTseries6 *
* Version 20.07.11.33 *
* Proprietary Program of *
* Bentley Systems, Inc. *
* Date= JUN 13, 2022 *
* Time= 18:58: 0 *
* USER ID: Swansea University *
1. STAAD SPACE DXF IMPORT OF LVL FRAME STAAD IMPORT
INPUT FILE: C:\Users\990076\Downloads\Hereford University Design Challenge.STD
2. START JOB INFORMATION
3. ENGINEER DATE 12-JUN-22
4. END JOB INFORMATION
5. SET Z UP
**WARNING- THE FOLLOWING COMMANDS SHOULD NOT BE USED WHEN THE SET Z UP
IS ALSO ENTERED: FLOOR LOAD, AREA LOAD, WIND LOAD, Nonlinear Cable Analysis
& GENERATION of SPRING SUPPORTS for ELASTIC MAT FOUNDATIONS
6. INPUT WIDTH 79
7. UNIT MMS NEWTON
8. JOINT COORDINATES
9. 1 0 2114.36 0; 2 0 8923.86 1557.94; 3 0 2114.36 -3384.12; 4 0 18769.4 1899.45
10. 5 0 15733.4 3115.88; 6 0 18769.4 -3384.12; 7 -19799.6 18769.8 1899.45
11. 8 -28770 18770 1899.45; 9 -28770 15734 3115.88; 10 -28770 18770 -3384.12
12. 11 -28770 2114.36 -3384.12; 12 -28770 2114.96 0; 13 -28770 8983.36 1571.42
13. 14 -28770 8983.36 -3384.12; 15 -28770 15734 -3384.12; 16 0 8982.75 -3384.12
14. 17 0 15733.4 -3384.12; 18 -24322.7 18770 -3384.12; 19 -24322.7 18770 1899.45
15. 20 -19799.6 18770 -3384.12; 21 -16783.4 18770 -3384.12
16. 22 -16783 18770 1899.45; 23 -13768.4 18770 -3384.12; 24 -13768.4 18770 1899.45
17. 25 -10759.3 18769.4 -3384.12; 26 -10759.3 18769.4 1899.45
18. 27 -4337.63 18769.4 -3384.12; 28 -4337.63 18769.4 1899.45
19. 29 -8567.76 18769.4 -3384.12; 30 -8567.76 18769.4 1899.45
20. 31 -25676 2114.36 -3384.12; 32 -25676 2114.96 0; 33 -22731.9 2114.36 -3384.12
21. 34 -22731.9 2114.96 0; 35 -19787.8 2114.36 -3384.12; 36 -19787.8 2114.96 0
22. 37 -16175 2114.36 -3384.12; 38 -16175 2114.96 0; 39 -10730 2114.71 -3384.12
23. 40 -10730 2115.32 0; 41 -4342.62 2114.71 -3384.12; 42 -4342.62 2115.32 0
24. 43 -8559.12 2114.18 -3384.12; 44 -8559.12 2114.79 0.000387574
25. 45 -28770 18770.5 -484.118; 46 -28770 15733.7 -484.118
26. 47 -19787.4 15734.6 -484.118; 48 -13452.5 2112.71 -3384.12
27. 49 -13452.5 2113.32 0; 50 -24322.7 15733.7 -484.118
28. 51 -24322.7 15733.7 -3384.12; 52 -19787.4 15733.4 -3384.12
29. 53 -16783.4 15733.7 -484.118; 54 -16783.4 15733.4 -3384.12
30. 55 -13768.4 15733.7 -484.118; 56 -13768.4 15733.4 -3384.12
31. 57 -10753.4 15733.7 -484.118; 58 -10753.4 15733.4 -3384.12
32. 59 -10753.4 18770.5 -484.661; 60 -13768.4 18770.5 -484.661
DXF IMPORT OF LVL FRAME STAAD IMPORT -- PAGE NO. 2
33. 61 -10759.3 8923.86 1557.94; 62 -10759.3 15733.4 3115.88
34. 63 -10759.3 8982.75 -3384.12; 64 -4337.63 8982.75 1571.42
35. 65 -4337.63 8982.75 -3384.12; 66 -8567.76 8982.75 1571.42
36. 67 -8567.76 8982.75 -3384.12; 68 -8567.76 15733.4 3115.88
37. 69 -8567.76 15733.4 -3384.12; 70 -19787.8 8983.36 1571.42
38. 71 -24284.8 15733.9 3115.88; 72 -19799.6 15733.8 3115.88
39. 73 -16783.4 15734 3115.88; 74 -13768.4 15734 3115.88
40. 75 -27870.3 15732.8 -484.118; 76 -27870.3 18769.6 -484.661
41. 77 -26970.7 15731.9 -484.118; 78 -26970.7 18768.7 -484.661
42. 79 -26071 15731.1 -484.119; 80 -26071 18767.9 -484.661
43. 81 -25171.3 15730.2 -484.119; 82 -25171.3 18767 -484.661
44. 83 -24284.8 18770.2 -484.118; 84 -23378.9 15733.7 -484.118
45. 85 -23378.9 18770.5 -484.661; 86 -22479.2 15732.8 -484.118
46. 87 -22479.2 18769.6 -484.661; 88 -21579.6 15732.8 -484.119
47. 89 -21579.6 18769.6 -484.661; 90 -20679.9 15731.9 -484.119
48. 91 -20679.9 18768.7 -484.661; 92 -19780.2 18767.9 -484.661
49. 93 -18880.6 15732.8 -484.119; 94 -18880.6 18769.6 -484.662
50. 95 -17980.9 15731.9 -484.119; 96 -17980.9 18768.7 -484.662
51. 97 -17081.2 15731.1 -484.119; 98 -17081.2 18767.9 -484.662
52. 99 -16181.6 15730.2 -484.119; 100 -16181.6 18767 -484.662
53. 101 -15281.9 15732.8 -484.12; 102 -15281.9 18769.6 -484.663
54. 103 -14382.2 15732.8 -484.12; 104 -14382.2 18769.6 -484.663
55. 105 -13482.6 15732.8 -484.121; 106 -13482.6 18769.6 -484.663
56. 107 -12582.9 15731.9 -484.121; 108 -12582.9 18768.7 -484.663
57. 109 -11683.2 15731.1 -484.121; 110 -11683.2 18767.9 -484.663
58. 111 -4382.04 15733.4 3115.88; 112 -25676 8983.36 1571.3
59. 113 -25676 8983.09 -3384.12; 114 -22731.9 8983.36 1571.3
60. 115 -22731.9 8983.09 -3384.12; 116 -19787.8 8983.09 -3384.12
61. 117 -16175 8983.36 1571.3; 118 -16175 8983.09 -3384.12
62. 119 -13452.5 8983.36 1571.3; 120 -13452.5 8983.09 -3384.12
63. 121 -16783 18770 -484; 122 -28320 18770 1899.4; 123 -27870 18770 1899.4
64. 124 -27420 18770 1899.4; 125 -26970 18770 1899.4; 126 -26520 18770 1899.4
65. 127 -26070 18770 1899.4; 128 -25620 18770 1899.4; 129 -25170 18770 1899.4
66. 130 -24720 18770 1899.4; 131 -24270 18770 1899.4; 132 -23820 18770 1899.4
67. 133 -23370 18770 1899.4; 134 -22920 18770 1899.4; 135 -22470 18770 1899.4
68. 136 -22020 18770 1899.4; 137 -21570 18770 1899.4; 138 -21120 18770 1899.4
69. 139 -20670 18770 1899.4; 140 -20220 18770 1899.4; 141 -19770 18770 1899.4
70. 142 -19320 18770 1899.4; 143 -18870 18770 1899.4; 144 -18420 18770 1899.4
71. 145 -17970 18770 1899.4; 146 -17520 18770 1899.4; 147 -17070 18770 1899.4
72. 148 -16620 18770 1899.4; 149 -16170 18770 1899.4; 150 -15720 18770 1899.4
73. 151 -15270 18770 1899.4; 152 -14820 18770 1899.4; 153 -14370 18770 1899.4
74. 154 -13920 18770 1899.4; 155 -13470 18770 1899.4; 156 -13020 18770 1899.4
75. 157 -12570 18770 1899.4; 158 -12120 18770 1899.4; 159 -11670 18770 1899.4
76. 160 -11220 18770 1899.4; 161 -10770 18770 1899.4; 162 -10320 18770 1899.4
77. 163 -9870 18770 1899.4; 164 -9420 18770 1899.4; 165 -8970 18770 1899.4
78. 166 -8520 18770 1899.4; 167 -8070 18770 1899.4; 168 -7620 18770 1899.4
79. 169 -7170 18770 1899.4; 170 -6720 18770 1899.4; 171 -6270 18770 1899.4
80. 172 -5820 18770 1899.4; 173 -5370 18770 1899.4; 174 -4920 18770 1899.4
81. 175 -4470 18770 1899.4; 176 -4020 18770 1899.4; 177 -3570 18770 1899.4
82. 178 -3120 18770 1899.4; 179 -2670 18770 1899.4; 180 -2220 18770 1899.4
83. 181 -1770 18770 1899.4; 182 -1320 18770 1899.4; 183 -870 18770 1899.4
84. 184 -420 18770 1899.4; 185 -28320 2115 0; 186 -27870 2115 0; 187 -27420 2115 0
85. 188 -26970 2115 0; 189 -26520 2115 0; 190 -26070 2115 0; 191 -25620 2115 0
86. 192 -25170 2115 0; 193 -24720 2115 0; 194 -24270 2115 0; 195 -23820 2115 0
87. 196 -23370 2115 0; 197 -22920 2115 0; 198 -22470 2115 0; 199 -22020 2115 0
88. 200 -21570 2115 0; 201 -21120 2115 0; 202 -20670 2115 0; 203 -20220 2115 0
DXF IMPORT OF LVL FRAME STAAD IMPORT -- PAGE NO. 3
89. 204 -19770 2115 0; 205 -19320 2115 0; 206 -18870 2115 0; 207 -18420 2115 0
90. 208 -17970 2115 0; 209 -17520 2115 0; 210 -17070 2115 0; 211 -16620 2115 0
91. 212 -16170 2115 0; 213 -15720 2115 0; 214 -15270 2115 0; 215 -14820 2115 0
92. 216 -14370 2115 0; 217 -13920 2115 0; 218 -13470 2115 0; 219 -13020 2115 0
93. 220 -12570 2115 0; 221 -12120 2115 0; 222 -11670 2115 0; 223 -11220 2115 0
94. 224 -10770 2115 0; 225 -10320 2115 0; 226 -9870 2115 0; 227 -9420 2115 0
95. 228 -8970 2115 0; 229 -8520 2115 0; 230 -8070 2115 0; 231 -7620 2115 0
96. 232 -7170 2115 0; 233 -6720 2115 0; 234 -6270 2115 0; 235 -5820 2115 0
97. 236 -5370 2115 0; 237 -4920 2115 0; 238 -4470 2115 0; 239 -4020 2115 0
98. 240 -3570 2115 0; 241 -3120 2115 0; 242 -2670 2115 0; 243 -2220 2115 0
99. 244 -1770 2115 0; 245 -1320 2115 0; 246 -870 2115 0; 247 -420 2115 0
100. 248 -28320 15734 3115.9; 249 -27870 15734 3115.9; 250 -27420 15734 3115.9
101. 251 -26970 15734 3115.9; 252 -26520 15734 3115.9; 253 -26070 15734 3115.9
102. 254 -25620 15734 3115.9; 255 -25170 15734 3115.9; 256 -24720 15734 3115.9
103. 257 -24270 15734 3115.9; 258 -23820 15734 3115.9; 259 -23370 15734 3115.9
104. 260 -22920 15734 3115.9; 261 -22470 15734 3115.9; 262 -22020 15734 3115.9
105. 263 -21570 15734 3115.9; 264 -21120 15734 3115.9; 265 -20670 15734 3115.9
106. 266 -20220 15734 3115.9; 267 -19770 15734 3115.9; 268 -19320 15734 3115.9
107. 269 -18870 15734 3115.9; 270 -18420 15734 3115.9; 271 -17970 15734 3115.9
108. 272 -17520 15734 3115.9; 273 -17070 15734 3115.9; 274 -16620 15734 3115.9
109. 275 -16170 15734 3115.9; 276 -15720 15734 3115.9; 277 -15270 15734 3115.9
110. 278 -14820 15734 3115.9; 279 -14370 15734 3115.9; 280 -13920 15734 3115.9
111. 281 -13470 15734 3115.9; 282 -13020 15734 3115.9; 283 -12570 15734 3115.9
112. 284 -12120 15734 3115.9; 285 -11670 15734 3115.9; 286 -11220 15734 3115.9
113. 287 -10770 15734 3115.9; 288 -10320 15734 3115.9; 289 -9870 15734 3115.9
114. 290 -9420 15734 3115.9; 291 -8970 15734 3115.9; 292 -8520 15734 3115.9
115. 293 -8070 15734 3115.9; 294 -7620 15734 3115.9; 295 -7170 15734 3115.9
116. 296 -6720 15734 3115.9; 297 -6270 15734 3115.9; 298 -5820 15734 3115.9
117. 299 -5370 15734 3115.9; 300 -4920 15734 3115.9; 301 -4470 15734 3115.9
118. 302 -4020 15734 3115.9; 303 -3570 15734 3115.9; 304 -3120 15734 3115.9
119. 305 -2670 15734 3115.9; 306 -2220 15734 3115.9; 307 -1770 15734 3115.9
120. 308 -1320 15734 3115.9; 309 -870 15734 3115.9; 310 -420 15734 3115.9
121. 311 -28320 8983.4 1571.4; 312 -27870 8983.4 1571.4; 313 -27420 8983.4 1571.4
122. 314 -26970 8983.4 1571.4; 315 -26520 8983.4 1571.4; 316 -26070 8983.4 1571.4
123. 317 -25620 8983.4 1571.4; 318 -25170 8983.4 1571.4; 319 -24720 8983.4 1571.4
124. 320 -24270 8983.4 1571.4; 321 -23820 8983.4 1571.4; 322 -23370 8983.4 1571.4
125. 323 -22920 8983.4 1571.4; 324 -22470 8983.4 1571.4; 325 -22020 8983.4 1571.4
126. 326 -21570 8983.4 1571.4; 327 -21120 8983.4 1571.4; 328 -20670 8983.4 1571.4
127. 329 -20220 8983.4 1571.4; 330 -19770 8983.4 1571.4; 331 -19320 8983.4 1571.4
128. 332 -18870 8983.4 1571.4; 333 -18420 8983.4 1571.4; 334 -17970 8983.4 1571.4
129. 335 -17520 8983.4 1571.4; 336 -17070 8983.4 1571.4; 337 -16620 8983.4 1571.4
130. 338 -16170 8983.4 1571.4; 339 -15720 8983.4 1571.4; 340 -15270 8983.4 1571.4
131. 341 -14820 8983.4 1571.4; 342 -14370 8983.4 1571.4; 343 -13920 8983.4 1571.4
132. 344 -13470 8983.4 1571.4; 345 -13020 8983.4 1571.4; 346 -12570 8983.4 1571.4
133. 347 -12120 8983.4 1571.4; 348 -11670 8983.4 1571.4; 349 -11220 8983.4 1571.4
134. 350 -10770 8983.4 1571.4; 351 -10320 8983.4 1571.4; 352 -9870 8983.4 1571.4
135. 353 -9420 8983.4 1571.4; 354 -8970 8983.4 1571.4; 355 -8520 8983.4 1571.4
136. 356 -8070 8983.4 1571.4; 357 -7620 8983.4 1571.4; 358 -7170 8983.4 1571.4
137. 359 -6720 8983.4 1571.4; 360 -6270 8983.4 1571.4; 361 -5820 8983.4 1571.4
138. 362 -5370 8983.4 1571.4; 363 -4920 8983.4 1571.4; 364 -4470 8983.4 1571.4
139. 365 -4020 8983.4 1571.4; 366 -3570 8983.4 1571.4; 367 -3120 8983.4 1571.4
140. 368 -2670 8983.4 1571.4; 369 -2220 8983.4 1571.4; 370 -1770 8983.4 1571.4
141. 371 -1320 8983.4 1571.4; 372 -870 8983.4 1571.4; 373 -420 8983.4 1571.4
142. MEMBER INCIDENCES
143. 1 1 2; 2 3 1; 3 4 5; 4 6 4; 5 8 9; 6 10 8; 7 11 12; 8 12 13; 9 13 14; 10 9 15
144. 11 2 16; 12 5 17; 13 18 19; 14 20 7; 15 21 22; 16 23 24; 17 25 26; 18 27 28
DXF IMPORT OF LVL FRAME STAAD IMPORT -- PAGE NO. 4
145. 19 29 30; 20 31 32; 21 33 34; 22 35 36; 23 37 38; 24 39 40; 25 41 42; 26 43 44
146. 27 2 5; 28 13 14; 29 15 9; 30 10 45; 31 46 45; 32 12 32; 33 32 34; 34 34 36
147. 35 36 38; 36 48 49; 37 42 1; 38 50 51; 39 47 52; 40 53 54; 41 55 56; 42 47 53
148. 43 53 55; 44 57 58; 45 55 57; 46 57 59; 47 59 60; 48 26 62; 49 61 63; 50 62 58
149. 51 61 62; 52 64 65; 53 66 67; 54 68 69; 55 19 71; 56 7 72; 57 22 73; 58 24 74
150. 59 75 76; 60 77 78; 61 79 80; 62 81 82; 63 50 83; 64 84 85; 65 86 87; 66 88 89
151. 67 90 91; 68 47 92; 69 93 94; 70 95 96; 71 97 98; 72 99 100; 73 101 102
152. 74 103 104; 75 105 106; 76 107 108; 77 109 110; 78 44 66; 79 66 68; 80 68 30
153. 81 42 64; 82 64 111; 83 111 28; 84 112 113; 85 114 115; 86 70 116; 87 117 118
154. 88 119 120; 89 32 112; 90 34 114; 91 36 70; 92 38 117; 93 38 49; 94 49 40
155. 95 42 44; 96 44 40; 97 61 66; 98 66 64; 99 64 2; 100 111 68; 101 68 62
156. 102 111 5; 103 61 119; 104 119 117; 105 117 70; 106 70 114; 107 114 112
157. 108 112 13; 109 26 24; 110 24 22; 111 22 7; 112 7 19; 113 19 8; 114 9 71
158. 115 71 72; 116 72 73; 117 73 74; 118 74 62; 119 4 28; 120 28 30; 121 30 26
159. 122 45 83; 123 83 92; 124 92 121; 125 121 60; 126 61 40; 127 119 49; 128 46 50
160. 129 50 47
161. ELEMENT INCIDENCES SHELL
162. 130 45 59 57 46
163. ELEMENT PROPERTY
164. 130 THICKNESS 30
165. DEFINE MATERIAL START
166. ISOTROPIC TIMBER
167. E 10342.1
168. POISSON 0.15
169. DENSITY 3.92716E-006
170. ALPHA 3E-006
171. DAMP 0.06
172. G 4496.56
173. TYPE TIMBER
*********** END OF THE STAAD.Pro RUN ***********
**** DATE= JUN 13,2022 TIME= 18:58: 0 ****
DXF IMPORT OF LVL FRAME STAAD IMPORT -- PAGE NO. 5
* For technical assistance on STAAD.Pro, please visit *
* http://selectservices.bentley.com/en-US/ *
* Details about additional assistance from *
* Bentley and Partners can be found at program menu *
* Help->Technical Support *
* Copyright (c) 1997-2015 Bentley Systems, Inc.
* http://www.bentley.com *
Parents Reply Children
