Gusset Conncetion Modifications
Hi
I would like to my double angles rotated 90 deg and have bolted connection on one side only. Although I have created the model with a rotated double angle in the RAM Connection module it rotates it and put a gusset plate in middle. I don't want that.
Also, for the horizontal beam to column conneciton I would like to have angle bolted connection and (stiffener/gusset) plates on the back side of the joint on the column.
Please help me out here.
Ravikant
