I was trying to print a steel design report but i keep on getting this message as shown on the attached picture (there is no data of this type)
Staad model
3872.Structure1.STD
I am able to generate the report with your model.
Not sure what is the problem at your end. I am also using the same version. Just check if steel design tab, below settings are present.
Answer Verified By: Joseph Lucas Magare
I tried it is working for other member like member number 1 but i have now discovered this happens when i want to print design detail of beam 195,the result are not appearing in report
I tried to select basing on property
When i choose
1.R11, R12, R13, R14, R2,R3, R4, R5, R6, R7, R8, R9 (There is no data of this type)
2.R1 gives detailed design report
This is a known issue and it has been discussed here: Steel design output are not shown for some properties - RAM | STAAD Forum - RAM | STAAD | ADINA - Bentley Communities
Thanks, i have passed through discussion, and you advised not to use range option, now comes to my model if i need a design report of member number 195 which trick should i use?
