Stand panel loading - distribute to intermediate members
Can panel loading be used to distribute to intermediate members in the physical modeler? For example, if you had a square frame with steel beams on the perimeter and joists at 5 foot on center framing between two sides, can you bound the steel perimeter and have panel loading be assigned to the joists?
