The Bug ID 487652 is present only in the update 7 of staad or all versions of staad from 1 to 10 till date please clarify and this has to be resolved on priority as the bending capacity of slender section is not calculating as per Clause 8.2.1.2 of IS800-2007.
B.Mahesh Kumar.
This bug is present from the version 22 update 3. We are fixing the bug and hopefully it will be fixed in next build.
Dear Team,
whether the BUG ID 487652 is updated in the Latest update of Staad Version Update 11 .
B. Mahesh Kumar
This fix will be available in next build i.e. V12. We have internally fixed it. It is being tested by our team and will be available once satisfied with teh results after testing at our end.
IS IN LATEST UPDATE i.e. UPDATE 12 , 487652 BUG IS REMOVED OR NOT? IN THE LIST PARTICULER BUG ID IS NOT MENTIOND !!!
IS IT FIXED OR NOT? AS UPDATE 12 IS THERE
Answer Verified By: Mahesh Kumar Bandham
