the beam has failed in shear so i need to change the bar size and no. of legs, How to change the shear reinforcement number of leg and bar size in RCDC,
You can design the beams and then-
i cannot able edit it
how to attached the file here ?
https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/28129/how-can-i-upload-files-in-the-bentley-communities-forum
Follow the steps mentioned to upload file.
4299-21A-17-12-00XX-1-Culvert 4 -Type 2(with full slab model) - Column changed for RDCD.STD Hi sorry i cannot attach the RCDC since it has more capacity, Hence i have attached the STAAD file if possible can anyone solve this. The running time will be more for the STAAD also.
Thankyou Mr. Abhisek
upload the RCDC using secure file upload option.
https://communities.bentley.com/help/w/be_communities_help/7079/communities-secure-file-upload
