Nodal displacement between 2 nodes is huge but deflection passed.
The structure has a cantilever beam (node 107 to 169) to support the cladding wall as per figure 1. From Figure 2, the difference between 2 nodal displacements in Z-direction (node 107 and 169) is 7931.81mm. But from Figure 3, the deflection has no issue. Please explain on the theory behind. Thank you
                                          Figure 1
