Is there any way (such as programing cut lines into the input file/saving your cut lines) to not lose cut lines after making modifications to the model and re running the analysis?
I found a post about this two years ago and I'm not sure if any enhancements have been made since then.
Results Along Line - RAM | STAAD Forum - RAM | STAAD | ADINA - Bentley Communities
Thank you!
You can use OpenSTAAD function GetResultantForceAlongLineForPlateList for this task
