Staad.Pro - Seismic loads by response spectra
Hi, I need help defining seismic loads by using the response spectra line graph.  I add seismic periods and accelerations in the 'Load Case Details' section (attached image). I did not use the 'Definitions' section to consider seismic. My question is how to add loads to gather seismic loads in load case 12. I have used repeat load. Is this approach correct?
Parents Reply
  • Excuse me...
    1. I have done seismic loading with the method you mentioned. I have 1 note from the output, it says: ***NOTE: MASSES DEFINED UNDER LOAD#      10 WILL FORM
                THE FINAL MASS MATRIX FOR DYNAMIC ANALYSIS.
     EIGEN METHOD   : SUBSPACE
     NUMBER OF MODES REQUESTED              =   300
     NUMBER OF EXISTING MASSES IN THE MODEL = 38229
     NUMBER OF MODES THAT WILL BE USED      =   300
     Does it mean the analysis is not correct?
    1. And one more question. Some permanent loads are applied to plates in their local axis. Then I want to apply these loads in X/Y/Z. In input, loads have been indicated such as PR -50 kN. In the seismic load case, I write these loads as PR GX 50 kN, PR GY 50 kN, and PR GZ 50 kN. Is that correct?
