can someone please tell how to access results from stress at a point function of openstaad. i am trying hard to get but getting failure. please explain.
Greetings,
Please provide exact steps to repeat with names of application and their version numbers.
I cannot tell if you are using AutoPIPE exported some results to STAAD. Or if you had exported from STAAD into AutoPIPE.
Screen shots and exact steps to repeat would be a big help.
Regards, Mike Dattilio Design Analysis Engineering Group Senior Analyst Bentley Systems Inc=============================================================================
Thanks for the quick response Mr. Mike and sorry for the asking vague question.
Actually i am trying to extract the corner point stresses from staad pro using openstaad plate getplatestressatpoint function using vba. but i am not getting the definition of facing node start node and end node.
My real concern in that i want to have corner stresses of plates using openstaad vba function like the function we use GetAllPlateCenterStressesAndMoments for center stresses. Please guide me it will be very helpful.
As you may now know this is the WIKI page for AutoPIPE application and not STAAD. I will try and move this posting from
AutoPIPE> AutoPIPE Forum> Access results from stress at a point function of openstaad, to the OPENSTAAD forum.
OK this is now in the STAAD queue.
RAM | STAAD | ADINA> RAM | STAAD Forum > Access results from stress at a point function of openstaad.
