If i design Concrete plates in Staad pro C.E using BS 8007,does the software check for shear directly or i have to do it manually?
Shear check is not performed in BS 8007 in STAAD.Pro CE batch mode.
Answer Verified By: Joseph Lucas Magare
Ok thank you
Is there any technical manual demonstrating the design of plates using BS 8007,or any Ondemand video?
I am not aware of such, but the steps are the same as in any other design code.
I want to assign Scon parameter and crack width for plate element but it does not assign,what maybe the problem?
