By Which method,RCDC calculate K factor of column ? For Sway or Non -sway frame alignment chart or else ?
It follows annex-E of IS:456-2000 code. It is based on stability index calculation.
When a column in one direction has beam while the other direction does not have beam,do rcdc detect that automatically and select the appropriate effectiv3 length for design?
A validation of the same can be found in the below link.
https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/47981/indian-code---is-456--2000-is-13920-2016
look for below topic.
yes.. You can also use some limits or fixed value if required. See help file for details.
Thank you
