Under Physical modeling Wind load item are supposed to be included as Windward+ Leeward +sidewall, which I can not included in one wind load case, although i can add them as load item in one wind load case in analytical workflow. Is it possible?
Physical Modeler No option wo add
after transferring to Analytical modeler
Desired is as under, which is directly using wind load items in on wind load case e.g Wind+X and then 1) wind x 1Type1 +2_ wind -x etc using only analytical modeling, and not by P.M. to A.M.
Arun
This has already been reported to the product management team and a FEATURE 798875 has been posted for the same. Hope in some future release this feature will be added.
