In STAAD Pro SS6 edition (Version 20.07.11.70) when a member subjected to Combined Axial force and bending, the member fails with higher ratios (i.e., 200, 216584 etc. ) according to section 9.3.1.1 as per IS 800 - 2007 (LSD). But when I calculate manually for the Axial force and Moment for the STAAD section forces using the equation,
As per IS 800 - 2007, Section 9.3.1.1
I get Lesser value of ratios. Kindly confirm me, STAAD Pro SS6 edition (Version 20.07.11.70) uses which formula, for calculating section strength ratio for steel member design for code IS 800 - 2007
STAAD.Pro V8i is not supported anymore. Please upgrade to the most recent STAAD.Pro CONNECT Edition and check if you are getting the expected design results.
Additionally you may refer to the support policy in the link below:communities.bentley.com/.../bentley-support-policy
