I have created custom moment connection template in the connection design tab of STAAD Pro V8i Connect Edition Update 10. After creating the new item and moving it to moment connection database, it is not displayed or available for assigning the template to selected joints. Can you suggest a work around for this?
I am having the same issue with STAAD.Pro Advanced CONNECT Edition - Version 22.11.00.156.
I do not have the files listed in the solution posted by Modestas about a month ago. Did you reach any specific resolution to your question. Please share
This issue has been addressed in the STAAD.Pro CE version 22.11.00.156.Are you adding the custom connection to the database?Also, if the custom connection was selected as Optimizable, then you should be looking for it in the Smart Connections, else - Basic Connections.
Yeah I did both Smart and Basic based on the previous replies I saw. I still do not find the added template. I am looking in the group drop box. I am also looking under MEP available items. am I looking at the right place? Is there a check box I am missing, or are there restrictions on format which I am not aware of?
When you create a Table, you select the specific design code. So that custom connection will be added into the database of that design code. In your case (as per your screenshot) that custom connection should be in the AISC MEP database.
you are right. that is what I thought too. but I do not find it.
