I can't seem to get this "workaround" to work:
Importing grids (as dxf files) into the STAAD.Pro Physical Modeler - RAM | STAAD | ADINA Wiki - RAM | STAAD | ADINA - Bentley Communities
When I open a new physical model and go to ISM, I only see iTwin Services. When I use iTwin services, it will not pull from the repository I already created. See images below for errors.
This is from wiki:
Here is what I see:
What happens when I try to use isync:
The process worked fine at my end. Which STAAD.Pro and iTwin Analytical Synchronizer version are you using? If not the latest one (22.10.00.153 and 12.02.00.139) try to upgrade to these versions and see if that helps. Also, make sure that ISM Repository file is saved in your local hard disk.
Yes latest versions have been used. I did move the files locally, but with no success. Here is a LINK to the ISM Repository (which I can open in the synchronizer).
I am not sure what's happening here. Please create a Service Request and we will investigate it further from there.
