Concrete Lateral Columns eccentricites
Just to confirm, the Concrete Column design module uses the loads obtained from the Frame module with input from the gravity members (i.e. eccentric gravity loads at points around the face of the column) to design the concrete columns for the incidental gravity moments felt by edge concrete columns supporting interior steel gravity beams.
