IS800 2007 WSD syntax
The correct systax for using design code IS;800 2007 section 11 ( WSD ) is CODE IS800 WSD
If someone types IS800 2007 WSD , STAAD still runs the file but actual design is performed as per IS:800 1984  i,e, same as using syntax CODE INDIAN
This bug shall be removed from STAAD as it gives wrong picture to designer that IS:800 2007 is followed by Staad.
Parents Reply Children
